    Restart MagicMirror once a day
    13 Posts 4 Posters 2.6k Views 4 Watching
    • V
      veny
      Hello everyone! I noticed that the weather module freezes and does not update. I looked at the logs, there are no errors. The command pm2 restart magicmirror helps. Is it possible to make a script so that the command pm2 restart magicmirror is executed automatically once a day. Thanks in advance to everyone!
      S mumblebajM 3 Replies Last reply Reply Quote 0
        sdetweil @veny
        @veny pm2 can schedule restart
        https://pm2.keymetrics.io/docs/usage/restart-strategies/
          sdetweil @veny
          @veny also, weather is all in browser, so any error messages would appear in the browser developer window console
          ctrl-shift-i, select the console tab
          • R
            @sdetweil said in Restart MagicMirror once a day:
            Dear Sam,
            which file is called to start the mirror when I have used your install script?
            (I guess I have to insert the cron-related additions there…)
            Thanks,
            Ralf
              sdetweil @rkorell
              @rkorell you can do it from the commandline, OR the config file
              the config file I create is in the installers folder
              pm2_MagicMirror.json
              it looks like you can do
              pm2 restart xx --cron-restart
              AFTER the app was defined already
              • R
                Do you mean I can issue the above command and pm2 will store/keep this as configuration?
                This would be pretty cool…
                Wasn’t there a “pm2 save” or something like this???
                Ralf
                  sdetweil @rkorell
                  @rkorell yes, pm2 save will ‘save’ the config for use later
                  this cron feature is new to me. so I haven’t tested what you need to do…
                  read their doc
                  • R
                    @sdetweil Yupp. Have read.
                    For me it’s for later - just potential - use.
                    Currently I’m fine without daily restart.
                    Thanks for your explanation!
                    Ralf
                      sdetweil @rkorell
                      @rkorell yes, we still don’t know completely, BUT the OP asked for capability,
                      and here it is… already available in the tools we use…
                      this community thrives on contribution, and I hope others will be able to do that for this topic as well.
                      • mumblebajM
                        mumblebaj Module Developer @veny
                        @veny Just restarting the MM does not resolve the issue with the weather module freezing. We need to find why the weather module freezes. Maybe turn on Debug in the config and then see if there are any errors on the next freeze?
                          sdetweil @mumblebaj
                          @mumblebaj I think its this
                          https://github.com/MagicMirrorOrg/MagicMirror/issues/3687
                          • mumblebajM
                            mumblebaj Module Developer @sdetweil
                            @sdetweil Yeah, was reading that earlier when you posted it from another issue. Will see if I can pull the MM repo and have a look at the code in there.
                              sdetweil @mumblebaj
                              @mumblebaj the problem is we are passing back data, and not the response object
                              and we didn’t check to see if the response was valid(statusCode==200), and after that sometimes the data is trash
                              if you have MM installed, you HAVE the repo!
