    [MMM-NounishReminder] Nounish Event Reminder for your MM
    Scheduled Pinned Locked Moved Showcase
    4 Posts 2 Posters 2.6k Views 2 Watching
    • X
      xppaicyber Module Developer
      Description
      MMM-NounishReminder is a MagicMirror² module that displays Nounish community events and meetings in a clean, organized format. It helps community members stay informed about important recurring events like Noun O’Clock, NounsGG Weekly Calls, and other community gatherings.
      Key features:
      • Displays current ongoing events with remaining time
      • Shows upcoming events for the week
      • Supports daily and weekly recurring events
      • Timezone conversion capabilities
      • Clean, easy-to-read interface with event highlighting
      • Configurable display options
      Screenshots
      MMM-NounishReminder
      Installation
      1. Navigate to your MagicMirror’s modules directory:
      cd ~/MagicMirror/modules
      1. Clone this repository:
      git clone https://github.com/xppaicyberr/MMM-NounishReminder.git
      1. Add the module to your config/config.js file:
          module: "MMM-NounishReminder",
              events: [
                  { name: "Noun O'Clock", day: "daily", startTime: "21:00", duration: 0 },
                  { name: "NounsGG Weekly Call", day: "Saturday", startTime: "02:00", duration: 60 },
                  { name: "Lil Uncut Gems", day: "Tuesday", startTime: "11:15", duration: 60 },
                  { name: "Nouncil Call", day: "Thursday", startTime: "21:00", duration: 60 },
                  { name: "Lil Happy Hour", day: "Friday", startTime: "04:00", duration: 120 }
              updateInterval: 60 * 1000,
              showAllEvents: true,
              eventTimezone: 7,
              showLocalTime: true
      Configuration Options
      Option Description Default
      events Array of event objects containing name, day, startTime, and duration See example above
      updateInterval How often to update the display (in milliseconds) 60000 (1 minute)
      fadeSpeed Speed of fade animation when updating (in milliseconds) 1000
      showAllEvents Whether to show all events or only upcoming ones true
      debug Enable debug logging true
      eventTimezone Timezone offset where events were defined (e.g., 7 for GMT+7) 7
      showLocalTime Convert events to local time true
      Event Object Properties
      Property Description Example
      name Name of the event “Noun O’Clock”
      day Day of the week or “daily” “Monday” or “daily”
      startTime Start time in 24-hour format “21:00”
      duration Duration in minutes (0 for no duration) 60
      Changelog
      [1.0.0] - Initial Release
      • Display of current and upcoming Nounish events
      • Timezone conversion support
      • Configurable event list
      • Real-time updates
      • Current event highlighting
      • Daily and weekly event support
      • R
        rkorell Module Developer @xppaicyber
        @xppaicyber
        Cool!
        If I understood your structure and approach correctly than this nice module could be used for any of recurring events, because the events are declared in the config.js definition of the module.
        Unfortunately you have hard coded the header of the module
        header.innerHTML = "NOUNISH REMINDERS";
        Do you think it is possible to get this header configurable as well?
        This would be really great!
        Thanks a lot!
        Warm regards,
        Ralf
        X 1 Reply Last reply Reply Quote 0
        • X
          xppaicyber Module Developer @rkorell
          @rkorell
          Hi Ralf,
          Thank you for your feedback! I’m happy to let you know that I’ve implemented your suggestion to make the header configurable. The update is now complete and has been committed to the repository.
          You were absolutely right - the module can be used for any recurring events, and having a hardcoded header limited its flexibility. Now you can customize the header text through the config.js file using the new header option:
              position: "top_center",
                  // Your events here...
                  header: "MY CUSTOM HEADER" // Set this to whatever title you prefer!
          If you don’t specify a header value, it will default to “NOUNISH REMINDERS” for backward compatibility.
          You can see all the changes in the commit here: https://github.com/XppaiCyberr/MMM-NounishReminder/commit/a6ef032f91a0921f98adcaa5d05c88991e9f7fcb
          Thank you for the suggestion! It definitely makes the module more versatile for different use cases.
          Warm regards,
          XppaiCyberr
          • R
            Dear XppaiCyberr,
            this is awesome!
            Thanks a LOT.
            Warmest regards,
            Ralf
