    MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs
    43 Posts 7 Posters 8.6k Views 7 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @Volkae
      @Volkae said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
      MM is 2.30.0
      Okay, I can see this when I downgrade to 2.30.0. With 2.31.0 the issue doesn’t appear. That was not the plan, but I’ll adjust requiresVersion accordingly.
      Please update MM and check whether this solves the issue for you 🙂
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @KristjanESPERANTO
        @Volkae note that you have to update nodejs again this release
        use my upgrade script it does all the work
        same place as the install script
        • mumblebajM Offline
          mumblebaj Module Developer @KristjanESPERANTO
          @KristjanESPERANTO Not sure if it is advisable to update the modules requiresVersion to the latest MM version. With the issue of older PI’s not able to run the latest version of MM you run the risk of the modules no longer working even if they can still work on older versions of MM. I prefer to keep my version 2 versions behind as they worked on those. Unless your module has specifically been updated with dependencies of the latest MM.
          • P Offline
            p1lspeda
            I can confirm: I have the same issue.
            Updated to latest node and MM version.
            Did a npm -install after updating MM and node. Unfortunately it did not have an effect.
            Any tips ?
            Error message:
            [2025-05-04 20:17:43.557] [ERROR] Error when loading MMM-PublicTransportHafas: require() of ES Module /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs not supported. Instead change the require of /home/pi/MagicMirror/modules/MMM-PublicTransportHafas/core/DepartureFetcher.mjs to a dynamic import() which is available in all CommonJS modules.
            • V Offline
              Volkae @sdetweil
              I used your upgrade script, update is completed, made an new install from MMM-PublicTransportHafas but it does not work
                sdetweil @Volkae
                @Volkae ok, did you do the apply ?
                do
                node -v
                cd ~/MagicMirror
                grep version package.json
                MagicMirror version should be 2.31.0
                V 1 Reply Last reply Reply Quote 1
                  sdetweil @p1lspeda
                  @p1lspeda just fyi, if you use the upgrade script it will npm install all the modules that have a package.json with dependencies after completing the MagicMirror upgrade
                    sdetweil @Volkae
                    @Volkae @p1lspeda @KristjanESPERANTO will have to advise next steps
                      KristjanESPERANTO Module Developer @sdetweil
                      @sdetweil said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                      I need the system information part from the logs. Like this:
                      [2025-01-14 20:05:03.529] [INFO]  System information:
                      ### SYSTEM:    manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false
                      ### OS:        platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.1.21-v8+
                      ### VERSIONS:  electron: 31.2.1; used node: 20.15.0; installed node: 22.4.1; npm: 10.8.1; pm2:
                      ### OTHER:     timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                      P V 2 Replies Last reply Reply Quote 0
                      • P Offline
                        @KristjanESPERANTO said in MMM-PublicTransportHafas - Error when loading - DeparturFetcher.mjs:
                        Here you go
                        [2025-05-06 06:46:30.229] [INFO]  System information:
                        ### SYSTEM:   manufacturer: ; model: ; virtual: false
                        ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.12.20+rpt-rpi-v8
                        ### VERSIONS: electron: 32.2.7; used node: 22.14.0; installed node: 22.14.0; npm: 10.9.2; pm2: 5.4.3
                        • 3 / 5
