    [ERROR] _ is not defined
    36 Posts 3 Posters 8.5k Views 3 Watching
      sdetweil @nowayto
      @nowayto weird, and npm start fails again _ not defined?
      i installed solarpicture without problems
      • N Offline
        nowayto @sdetweil
        I’m sure.I don’t think SolarPicture could be the problem.
        Yes, the error keep showing
          sdetweil @nowayto
          @nowayto wild, lets do this… intall MM again, but save the current…
          #backup MM config and modules list
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)"
          #rename the MagicMirror folder out of the way
          cd ~
          mv MagicMirror MagicMirror.save
          #and install MM again
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
          #restore the  MM config and modules
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
          then
          cd ~/MagicMirror
          npm start
          N 2 Replies Last reply Reply Quote 0
          • N Offline
            nowayto @sdetweil
            Before writing here I made backups, locally and on github, like you taught me in the past :)
            Now I’ll try
            • N Offline
              nowayto @sdetweil
              That’s incredible… I did it, everything goes good… no issues but when I start it
              npm start
              magicmirror@2.31.0 start
              npm run start:x11
              magicmirror@2.31.0 start:x11
              DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              [2025-05-11 22:44:21.593] [LOG] Starting MagicMirror: v2.31.0
              [2025-05-11 22:44:21.682] [LOG] Loading config …
              [2025-05-11 22:44:21.687] [LOG] config template file not exists, no envsubst
              [2025-05-11 22:44:23.250] [INFO] Checking config file /home/MYMIRR/MagicMirror/config/config.js …
              [2025-05-11 22:44:23.532] [INFO] Your configuration file doesn’t contain syntax errors :)
              [2025-05-11 22:44:23.535] [INFO] Checking modules structure configuration …
              [2025-05-11 22:44:23.824] [ERROR] _ is not defined
              Again this _ is not defined
                sdetweil @nowayto
                @nowayto wow!!! NOW i am really confused.
                have you rebooted?
                if you try the sample config.js
                cd ~/MagicMirror/config
                mv config.js config.js.save
                cp config.js.sample config.js
                and then
                npm start
                does it run or fail
                • N Offline
                  nowayto @sdetweil
                  Sam… I don’t know how to saying it.
                  I figure out the issue.
                  After your last message I tried what you suggest.
                  With the default cfg I had no errors, with mine I had errors.
                  So I checked again and again the config…
                  and I find an underscore _ right at the start of the config
                  npm config:check told me “no syntax errors” and that confusing me.
                  When I edit it I use nano editor
                  I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
                  Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.
                  In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
                  I’m really sorry for bothering you with that.
                  How can I buy you a coffee ?
                    sdetweil @nowayto
                    @nowayto no coffee needed, we found it!!!
                    please NEVER use sudo inside MagicMirror folder
                    no reason to use super user , just makes trouble later
                    so if you fix the config.js in the saved MagicMirror folder then it should run ok too!!!"
                    ill see what we can do about the misleading message… thanks for your energy here!!!
                    S N 3 Replies Last reply Reply Quote 0
                      @nowayto i use ctrl-end on my keyboard for nano to get to end of file
                      haven’t found a way to do that on my chromebook, drives me crazy!!!
                        @nowayto ok, I’ve found the error producer
                        and I’ll propose a fix…
                        I think this might have been more useful lol
                        [ERROR] fatal error in /home/sam/MagicMirror/config/config.js at line 19 column 1,  _ is not defined
                        I opened
                        https://github.com/MagicMirrorOrg/MagicMirror/issues/3785
                        for this issue
                        • 3 / 4
