    [ERROR] _ is not defined
    36 Posts 3 Posters 12.7k Views 3 Watching
    • N
      nowayto @sdetweil
      @sdetweil Thank you a lot Sam.
      I did everything but
      I have an [ERROR] _ is not defined
      magicmirror@2.31.0 start:x11
      [2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
      [2025-05-11 15:39:26.527] [LOG] Loading config …
      [2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
      [2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
      [2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
      [2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
      [2025-05-11 15:39:28.793] [ERROR] _ is not defined
        sdetweil @nowayto
        @nowayto so that sounds like the npm install failed again
        do it again and show the output
        N 1 Reply Last reply
        • N
          nowayto @sdetweil
          installer didn’t failed, but this is the result now
          npm install
          magicmirror@2.31.0 postinstall
          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
          magicmirror@2.31.0 install-vendor
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          up to date in 7s
          magicmirror@2.31.0 install-fonts
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
          Installing fonts …
          up to date in 3s
          magicmirror@2.31.0 prepare
          [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
          up to date in 45s
          285 packages are looking for funding
          run npm fund for details
            sdetweil @nowayto
            @nowayto weird, and npm start fails again _ not defined?
            i installed solarpicture without problems
            • N
              nowayto @sdetweil
              I’m sure.I don’t think SolarPicture could be the problem.
              Yes, the error keep showing
                sdetweil @nowayto
                @nowayto wild, lets do this… intall MM again, but save the current…
                #backup MM config and modules list
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)"
                #rename the MagicMirror folder out of the way
                cd ~
                mv MagicMirror MagicMirror.save
                #and install MM again
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                #restore the  MM config and modules
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
                then
                npm start
                N 2 Replies Last reply
                • N
                  nowayto @sdetweil
                  Before writing here I made backups, locally and on github, like you taught me in the past :)
                  Now I’ll try
                  • N
                    nowayto @sdetweil
                    That’s incredible… I did it, everything goes good… no issues but when I start it
                    npm start
                    npm run start:x11
                    [2025-05-11 22:44:21.593] [LOG] Starting MagicMirror: v2.31.0
                    [2025-05-11 22:44:21.682] [LOG] Loading config …
                    [2025-05-11 22:44:21.687] [LOG] config template file not exists, no envsubst
                    [2025-05-11 22:44:23.250] [INFO] Checking config file /home/MYMIRR/MagicMirror/config/config.js …
                    [2025-05-11 22:44:23.532] [INFO] Your configuration file doesn’t contain syntax errors :)
                    [2025-05-11 22:44:23.535] [INFO] Checking modules structure configuration …
                    [2025-05-11 22:44:23.824] [ERROR] _ is not defined
                    Again this _ is not defined
                      sdetweil @nowayto
                      @nowayto wow!!! NOW i am really confused.
                      have you rebooted?
                      if you try the sample config.js
                      cd ~/MagicMirror/config
                      mv config.js config.js.save
                      cp config.js.sample config.js
                      and then
                      npm start
                      does it run or fail
                      • N
                        nowayto @sdetweil
                        Sam… I don’t know how to saying it.
                        I figure out the issue.
                        After your last message I tried what you suggest.
                        With the default cfg I had no errors, with mine I had errors.
                        So I checked again and again the config…
                        and I find an underscore _ right at the start of the config
                        npm config:check told me “no syntax errors” and that confusing me.
                        When I edit it I use nano editor
                        I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
                        Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.
                        In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
                        I’m really sorry for bothering you with that.
                        How can I buy you a coffee ?
                          sdetweil @nowayto
                          @nowayto no coffee needed, we found it!!!
                          please NEVER use sudo inside MagicMirror folder
                          no reason to use super user , just makes trouble later
                          so if you fix the config.js in the saved MagicMirror folder then it should run ok too!!!"
                          ill see what we can do about the misleading message… thanks for your energy here!!!
                          S N 3 Replies Last reply
                            @nowayto i use ctrl-end on my keyboard for nano to get to end of file
                            haven’t found a way to do that on my chromebook, drives me crazy!!!
                              @nowayto ok, I’ve found the error producer
                              and I’ll propose a fix…
                              I think this might have been more useful lol
                              [ERROR] fatal error in /home/sam/MagicMirror/config/config.js at line 19 column 1,  _ is not defined
                              I opened
                              https://github.com/MagicMirrorOrg/MagicMirror/issues/3785
                              for this issue
                              • N
                                nowayto @sdetweil
                                @sdetweil Ok but I wanna just offer a coffe for your kind and your time spent with that.
                                Do you suggest me to fix the old magic mirror folder or just rm it?
                                  sdetweil @nowayto
                                  @nowayto if you have everything working, you can rm it
                                  i was just saying you could prove this change would fix the prior install
                                  i do this for fun, really! pay it forward, help someone else on whatever when you can.
                                  R 1 Reply Last reply
                                    awesome!
                                    highly appreciated!
                                    Ralf
                                    S N 2 Replies Last reply
                                      sdetweil @rkorell
                                      @rkorell I meet the most amazing people, with the most amazing ideas… and I get to help them?!
                                      what more can you ask for?!
                                      • N
                                        nowayto @rkorell
                                        @rkorell Again, thank you Sam.
                                        I know what you mean, I usually act as you said.
                                        I like to help other, in the subject where I have knowledge.
                                        So, thank you again
                                          sdetweil @nowayto
                                          @nowayto there is a better fix, coming in the next release…
