    [ERROR] _ is not defined
    36 Posts 3 Posters 12.7k Views 3 Watching
    • N
      nowayto @sdetweil
      Upgrade started - Sat May 10 00:06:51 CEST 2025
      system is Linux magicmirror2 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
      the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIK>
      architecture from dpkg is armhf
      ^[[96mCheck current Node installation …^[[0m
      ^[[0mNode currently installed. Checking version number.
      ^[[0mMinimum Node version: ^[[1mv22.14.0^[[0m
      ^[[0mInstalled Node version: ^[[1mv22.15.0^[[0m
      ^[[92mNo Node.js upgrade necessary.^[[0m
      ^[[96mCheck current NPM installation …^[[0m
      ^[[0mNPM currently installed. Checking version number.
      ^[[0mMinimum npm version: ^[[1mV10.9.2^[[0m
      ^[[0mInstalled npm version: ^[[1mV11.3.0^[[0m
      ^[[92mNo npm upgrade necessary.^[[0m
      saving custom.css
      remote name = origin
      upgrading from version 2.31.0 to 2.31.0
      fetching latest revisions
      git fetch rc=0
      current branch = master
      On branch master
      Your branch is up to date with ‘origin/master’.
      Untracked files:
      (use “git add …” to include in what will be committed)
      core
      errorcal.txt
      errorcal2.txt
      errorcal3.txt
      errorcal4.txt
      errorcal5.txt
      nohup.out
      run-start.sh
      splashscreen/
      nothing added to commit but untracked files present (use “git add” to track)
      no files different from github version
      • N
        nowayto @sdetweil
        @sdetweil npm install results
        ~/MagicMirror $ npm install
        npm error code ENOTEMPTY
        npm error syscall rename
        npm error path /home/MYMIRR/MagicMirror/node_modules/es-abstract
        npm error dest /home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi
        npm error errno -39
        npm error ENOTEMPTY: directory not empty, rename ‘/home/MYMIRR/MagicMirror/node_modules/es-abstract’ -> ‘/home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi’
        npm error A complete log of this run can be found in: /home/MYMIRR/.npm/_logs/2025-05-10T06_40_55_661Z-debug-0.log
        Tried with sudo
        ~/MagicMirror $ sudo npm install
        npm error code EBADENGINE
        npm error engine Unsupported engine
        npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
        npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
        npm error notsup Required: {“node”:“>=22.14.0”}
        npm error notsup Actual: {“npm”:“11.2.0”,“node”:“v20.18.1”}
        npm error A complete log of this run can be found in: /root/.npm/_logs/2025-05-10T06_41_52_949Z-debug-0.log
        npm seems to see an old version of nodejs but:
        ~/MagicMirror $ node -v
        v22.15.0
        I don’t know what happened.
        If it can help I had first problem after the MMM-SolarPicture
        but I’ve just installed it and configured it through config.js… nothing more than usual…
        but the actual behaviour is that pm2 status says it’s running, but on the monitor I see just the raspbian desktop
        │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
        │ 0 │ mm │ default │ N/A │ fork │ 4311 │ 19s │ 64 │ online │ 0% │ 2.6mb │ ber… │ disabled │
          sdetweil @nowayto
          @nowayto two things
          doing test run changes nothing, its a safety check
          and i wont let you upgrade over the same release accidentally
          so you need to rerun the command and add
          force
          to the end
            @nowayto NEVER use sudo with any npm command
            the number in the pm2 status 4311 is the number of restarts
            youve got a mess
            now we HAVE to use sudo to undo it
            sudo rm -rf node_modules
            cd fonts
            cd ..\vendor
            sudo rm-rf node_modules
            cd ..
            lets see about node
            which node
            n
            q to quit
            nvm
            dont do anything else til we figure out the nodejs problem
            N 1 Reply Last reply
            • N
              nowayto @sdetweil
              @sdetweil I’m sorry :(
              I did it what you suggest and config:check gave me a module error again. Different than one before
              npm run config:check
              magicmirror@2.31.0 config:check
              node js/check_config.js
              node:internal/modules/cjs/loader:1404
              throw err;
              Error: Cannot find module ‘ajv’
              Require stack:
              After “require stack” there are other lines, if you need it, tell me.
                sdetweil @nowayto
                @nowayto
                i said stop
                we need to fix nodejs so npm install will work
                node -v
                says something
                and npm install says node is different
                i am trying to figure out where node is installed and by who
                system, nvm or n
                you didn’t give me answers to the commands i provided
                • N
                  nowayto @sdetweil
                  which node gave me
                  /home/MYMIRR/.nvm/versions/node/v22.15.0/bin/node
                  n gave me
                  node/20.18.1
                  Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
                  nvm gave me
                  Node Version Manager (v0.39.5)
                  Note: refers to any version-like string nvm understands. This includes :
                  • full or partial version numbers, starting with an optional “v” (0.10, v0.1.2 , v1)
                  • default (built-in) aliases: node, stable, unstable, iojs, system
                  • custom aliases you define with nvm alias foo
                  followed by a lot of options
                    sdetweil @nowayto
                    @nowayto ok nvm and n do the same function but differently
                    i use n in my scripts because it runs everywhere
                    so lets turn off nvm
                    nvm deactivate
                    nvm unload
                    cd ~
                    rm -rf  .nvm
                    now which node
                    should find /usr/local/bin/node
                    now we need n to get to node 22.14.0
                    sudo n 22.14.0
                    now node -v
                    should return 22.14.0
                    if so, do
                    cd  ~/MagicMirror
                    npm install
                    now MagicMirror should run
                    • N
                      nowayto @sdetweil
                      @sdetweil Thank you a lot Sam.
                      I did everything but
                      I have an [ERROR] _ is not defined
                      magicmirror@2.31.0 start:x11
                      [2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
                      [2025-05-11 15:39:26.527] [LOG] Loading config …
                      [2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
                      [2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
                      [2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
                      [2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
                      [2025-05-11 15:39:28.793] [ERROR] _ is not defined
                        sdetweil @nowayto
                        @nowayto so that sounds like the npm install failed again
                        do it again and show the output
                        • N
                          nowayto @sdetweil
                          installer didn’t failed, but this is the result now
                          npm install
                          magicmirror@2.31.0 postinstall
                          npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                          magicmirror@2.31.0 install-vendor
                          echo "Installing vendor files …
                          " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                          up to date in 7s
                          magicmirror@2.31.0 install-fonts
                          echo "Installing fonts …
                          " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                          Installing fonts …
                          up to date in 3s
                          magicmirror@2.31.0 prepare
                          [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                          up to date in 45s
                          285 packages are looking for funding
                          run npm fund for details
                            sdetweil @nowayto
                            @nowayto weird, and npm start fails again _ not defined?
                            i installed solarpicture without problems
                            • N
                              nowayto @sdetweil
                              I’m sure.I don’t think SolarPicture could be the problem.
                              Yes, the error keep showing
                                sdetweil @nowayto
                                @nowayto wild, lets do this… intall MM again, but save the current…
                                #backup MM config and modules list
                                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)"
                                #rename the MagicMirror folder out of the way
                                cd ~
                                mv MagicMirror MagicMirror.save
                                #and install MM again
                                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                #restore the  MM config and modules
                                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
                                then
                                npm start
                                N 2 Replies Last reply
                                • N
                                  nowayto @sdetweil
                                  Before writing here I made backups, locally and on github, like you taught me in the past :)
                                  Now I’ll try
                                  • N
                                    nowayto @sdetweil
                                    That’s incredible… I did it, everything goes good… no issues but when I start it
                                    npm start
                                    npm run start:x11
                                    [2025-05-11 22:44:21.593] [LOG] Starting MagicMirror: v2.31.0
                                    [2025-05-11 22:44:21.682] [LOG] Loading config …
                                    [2025-05-11 22:44:21.687] [LOG] config template file not exists, no envsubst
                                    [2025-05-11 22:44:23.250] [INFO] Checking config file /home/MYMIRR/MagicMirror/config/config.js …
                                    [2025-05-11 22:44:23.532] [INFO] Your configuration file doesn’t contain syntax errors :)
                                    [2025-05-11 22:44:23.535] [INFO] Checking modules structure configuration …
                                    [2025-05-11 22:44:23.824] [ERROR] _ is not defined
                                    Again this _ is not defined
                                      sdetweil @nowayto
                                      @nowayto wow!!! NOW i am really confused.
                                      have you rebooted?
                                      if you try the sample config.js
                                      cd ~/MagicMirror/config
                                      mv config.js config.js.save
                                      cp config.js.sample config.js
                                      and then
                                      npm start
                                      does it run or fail
                                      • N
                                        nowayto @sdetweil
                                        Sam… I don’t know how to saying it.
                                        I figure out the issue.
                                        After your last message I tried what you suggest.
                                        With the default cfg I had no errors, with mine I had errors.
                                        So I checked again and again the config…
                                        and I find an underscore _ right at the start of the config
                                        npm config:check told me “no syntax errors” and that confusing me.
                                        When I edit it I use nano editor
                                        I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
                                        Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.
                                        In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
                                        I’m really sorry for bothering you with that.
                                        How can I buy you a coffee ?
                                          sdetweil @nowayto
                                          @nowayto no coffee needed, we found it!!!
                                          please NEVER use sudo inside MagicMirror folder
                                          no reason to use super user , just makes trouble later
                                          so if you fix the config.js in the saved MagicMirror folder then it should run ok too!!!"
                                          ill see what we can do about the misleading message… thanks for your energy here!!!
                                          S N 3 Replies Last reply
                                            @nowayto i use ctrl-end on my keyboard for nano to get to end of file
                                            haven’t found a way to do that on my chromebook, drives me crazy!!!
