    [ERROR] _ is not defined
    36 Posts 3 Posters 9.8k Views 3 Watching
      sdetweil @nowayto
      @nowayto yes, but its two steps
      one time without any parameters (test mode)
      and one time with apply
      all you have to do is click/copy the first time and run it
      then do the same on the second if the first ends successfully
      • N Offline
        nowayto @sdetweil
        @sdetweil MM doesn’t work.
        I tried a config check but I have this error now.
        I tried to “npm install eslint -g” but the error persist
        npm run config:check
        magicmirror@2.31.0 config:check
        node js/check_config.js
        node:internal/modules/cjs/loader:1404
        throw err;
        Error: Cannot find module ‘eslint’
        Require stack:
        • /home/MYMIRR/MagicMirror/js/check_config.js
          at Module._resolveFilename (node:internal/modules/cjs/loader:1401:15)
          at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19)
          at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22)
          at Module._load (node:internal/modules/cjs/loader:1211:37)
          at TracingChannel.traceSync (node:diagnostics_channel:322:14)
          at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
          at Module.require (node:internal/modules/cjs/loader:1487:12)
          at require (node:internal/modules/helpers:135:16)
          at Object. (/home/MYMIRR/MagicMirror/js/check_config.js:6:20)
          at Module._compile (node:internal/modules/cjs/loader:1730:14) {
          code: ‘MODULE_NOT_FOUND’,
          requireStack: [ ‘/home/MYMIRR/MagicMirror/js/check_config.js’ ]
        Node.js v22.15.0
          sdetweil @nowayto
          @nowayto show me the ~/MagicMirror/installers/upgrade.log
          note: I had a typo in log filename
          and then do
          npm install
          N 2 Replies Last reply Reply Quote 0
          • N Offline
            nowayto @sdetweil
            Upgrade started - Sat May 10 00:06:51 CEST 2025
            system is Linux magicmirror2 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
            the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIK>
            architecture from dpkg is armhf
            ^[[96mCheck current Node installation …^[[0m
            ^[[0mNode currently installed. Checking version number.
            ^[[0mMinimum Node version: ^[[1mv22.14.0^[[0m
            ^[[0mInstalled Node version: ^[[1mv22.15.0^[[0m
            ^[[92mNo Node.js upgrade necessary.^[[0m
            ^[[96mCheck current NPM installation …^[[0m
            ^[[0mNPM currently installed. Checking version number.
            ^[[0mMinimum npm version: ^[[1mV10.9.2^[[0m
            ^[[0mInstalled npm version: ^[[1mV11.3.0^[[0m
            ^[[92mNo npm upgrade necessary.^[[0m
            saving custom.css
            remote name = origin
            upgrading from version 2.31.0 to 2.31.0
            fetching latest revisions
            git fetch rc=0
            current branch = master
            On branch master
            Your branch is up to date with ‘origin/master’.
            Untracked files:
            (use “git add …” to include in what will be committed)
            core
            errorcal.txt
            errorcal2.txt
            errorcal3.txt
            errorcal4.txt
            errorcal5.txt
            nohup.out
            run-start.sh
            splashscreen/
            nothing added to commit but untracked files present (use “git add” to track)
            no files different from github version
            • N Offline
              nowayto @sdetweil
              @sdetweil npm install results
              ~/MagicMirror $ npm install
              npm error code ENOTEMPTY
              npm error syscall rename
              npm error path /home/MYMIRR/MagicMirror/node_modules/es-abstract
              npm error dest /home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi
              npm error errno -39
              npm error ENOTEMPTY: directory not empty, rename ‘/home/MYMIRR/MagicMirror/node_modules/es-abstract’ -> ‘/home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi’
              npm error A complete log of this run can be found in: /home/MYMIRR/.npm/_logs/2025-05-10T06_40_55_661Z-debug-0.log
              Tried with sudo
              ~/MagicMirror $ sudo npm install
              npm error code EBADENGINE
              npm error engine Unsupported engine
              npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
              npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
              npm error notsup Required: {“node”:“>=22.14.0”}
              npm error notsup Actual: {“npm”:“11.2.0”,“node”:“v20.18.1”}
              npm error A complete log of this run can be found in: /root/.npm/_logs/2025-05-10T06_41_52_949Z-debug-0.log
              npm seems to see an old version of nodejs but:
              ~/MagicMirror $ node -v
              v22.15.0
              I don’t know what happened.
              If it can help I had first problem after the MMM-SolarPicture
              but I’ve just installed it and configured it through config.js… nothing more than usual…
              but the actual behaviour is that pm2 status says it’s running, but on the monitor I see just the raspbian desktop
              │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
              │ 0 │ mm │ default │ N/A │ fork │ 4311 │ 19s │ 64 │ online │ 0% │ 2.6mb │ ber… │ disabled │
                sdetweil @nowayto
                @nowayto two things
                doing test run changes nothing, its a safety check
                and i wont let you upgrade over the same release accidentally
                so you need to rerun the command and add
                force
                to the end
                  @nowayto NEVER use sudo with any npm command
                  the number in the pm2 status 4311 is the number of restarts
                  youve got a mess
                  now we HAVE to use sudo to undo it
                  sudo rm -rf node_modules
                  cd fonts
                  cd ..\vendor
                  sudo rm-rf node_modules
                  cd ..
                  lets see about node
                  which node
                  n
                  q to quit
                  nvm
                  dont do anything else til we figure out the nodejs problem
                  • N Offline
                    nowayto @sdetweil
                    @sdetweil I’m sorry :(
                    I did it what you suggest and config:check gave me a module error again. Different than one before
                    throw err;
                    Error: Cannot find module ‘ajv’
                    Require stack:
                    After “require stack” there are other lines, if you need it, tell me.
                      sdetweil @nowayto
                      @nowayto
                      i said stop
                      we need to fix nodejs so npm install will work
                      node -v
                      says something
                      and npm install says node is different
                      i am trying to figure out where node is installed and by who
                      system, nvm or n
                      you didn’t give me answers to the commands i provided
                      • N Offline
                        nowayto @sdetweil
                        which node gave me
                        /home/MYMIRR/.nvm/versions/node/v22.15.0/bin/node
                        n gave me
                        node/20.18.1
                        Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
                        nvm gave me
                        Node Version Manager (v0.39.5)
                        Note: refers to any version-like string nvm understands. This includes :
                        • full or partial version numbers, starting with an optional “v” (0.10, v0.1.2 , v1)
                        • default (built-in) aliases: node, stable, unstable, iojs, system
                        • custom aliases you define with nvm alias foo
                        followed by a lot of options
                          sdetweil @nowayto
                          @nowayto ok nvm and n do the same function but differently
                          i use n in my scripts because it runs everywhere
                          so lets turn off nvm
                          nvm deactivate
                          nvm unload
                          cd ~
                          rm -rf  .nvm
                          now which node
                          should find /usr/local/bin/node
                          now we need n to get to node 22.14.0
                          sudo n 22.14.0
                          now node -v
                          should return 22.14.0
                          if so, do
                          cd  ~/MagicMirror
                          npm install
                          now MagicMirror should run
                          • N Offline
                            nowayto @sdetweil
                            @sdetweil Thank you a lot Sam.
                            I did everything but
                            I have an [ERROR] _ is not defined
                            magicmirror@2.31.0 start:x11
                            [2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
                            [2025-05-11 15:39:26.527] [LOG] Loading config …
                            [2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
                            [2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
                            [2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
                            [2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
                            [2025-05-11 15:39:28.793] [ERROR] _ is not defined
                              sdetweil @nowayto
                              @nowayto so that sounds like the npm install failed again
                              do it again and show the output
                              • N Offline
                                nowayto @sdetweil
                                installer didn’t failed, but this is the result now
                                npm install
                                magicmirror@2.31.0 postinstall
                                npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                                magicmirror@2.31.0 install-vendor
                                echo "Installing vendor files …
                                " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                up to date in 7s
                                magicmirror@2.31.0 install-fonts
                                echo "Installing fonts …
                                " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                Installing fonts …
                                up to date in 3s
                                magicmirror@2.31.0 prepare
                                [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                up to date in 45s
                                285 packages are looking for funding
                                run npm fund for details
                                  sdetweil @nowayto
                                  @nowayto weird, and npm start fails again _ not defined?
                                  i installed solarpicture without problems
                                  • N Offline
                                    nowayto @sdetweil
                                    I’m sure.I don’t think SolarPicture could be the problem.
                                    Yes, the error keep showing
                                      sdetweil @nowayto
                                      @nowayto wild, lets do this… intall MM again, but save the current…
                                      #backup MM config and modules list
                                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)"
                                      #rename the MagicMirror folder out of the way
                                      cd ~
                                      mv MagicMirror MagicMirror.save
                                      #and install MM again
                                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                      #restore the  MM config and modules
                                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
                                      then
                                      npm start
                                      • N Offline
                                        nowayto @sdetweil
                                        Before writing here I made backups, locally and on github, like you taught me in the past :)
                                        Now I’ll try
                                        • N Offline
                                          nowayto @sdetweil
                                          That’s incredible… I did it, everything goes good… no issues but when I start it
                                          npm start
                                          npm run start:x11
                                          [2025-05-11 22:44:21.593] [LOG] Starting MagicMirror: v2.31.0
                                          [2025-05-11 22:44:21.682] [LOG] Loading config …
                                          [2025-05-11 22:44:21.687] [LOG] config template file not exists, no envsubst
                                          [2025-05-11 22:44:23.250] [INFO] Checking config file /home/MYMIRR/MagicMirror/config/config.js …
                                          [2025-05-11 22:44:23.532] [INFO] Your configuration file doesn’t contain syntax errors :)
                                          [2025-05-11 22:44:23.535] [INFO] Checking modules structure configuration …
                                          [2025-05-11 22:44:23.824] [ERROR] _ is not defined
                                          Again this _ is not defined
                                            sdetweil @nowayto
                                            @nowayto wow!!! NOW i am really confused.
                                            have you rebooted?
                                            if you try the sample config.js
                                            cd ~/MagicMirror/config
                                            mv config.js config.js.save
                                            cp config.js.sample config.js
                                            and then
                                            npm start
                                            does it run or fail
