    [ERROR] _ is not defined
    36 Posts 3 Posters 8.8k Views 3 Watching
    • N Offline
      nowayto @sdetweil
      @sdetweil I didn’t update MM since I’ve installed it months ago, so I suppose it wasn’t that. Might be it updated automatically?
      I remember you told me to use a “temp fix” to solve a problem.
      Now I’ll follow your guide in the post to update it.
      • N Offline
        nowayto @sdetweil
        @sdetweil Do you suggest to update manually or auto? Thanks
          sdetweil @nowayto
          @nowayto i never suggest update automatically.
          use my script
          • N Offline
            nowayto @sdetweil
            @sdetweil I’m sorry for the question: that script?
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              sdetweil @nowayto
              @nowayto yes, but its two steps
              one time without any parameters (test mode)
              and one time with apply
              all you have to do is click/copy the first time and run it
              then do the same on the second if the first ends successfully
              • N Offline
                nowayto @sdetweil
                @sdetweil MM doesn’t work.
                I tried a config check but I have this error now.
                I tried to “npm install eslint -g” but the error persist
                npm run config:check
                magicmirror@2.31.0 config:check
                node js/check_config.js
                node:internal/modules/cjs/loader:1404
                throw err;
                Error: Cannot find module ‘eslint’
                Require stack:
                • /home/MYMIRR/MagicMirror/js/check_config.js
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1401:15)
                  at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19)
                  at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22)
                  at Module._load (node:internal/modules/cjs/loader:1211:37)
                  at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                  at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                  at Module.require (node:internal/modules/cjs/loader:1487:12)
                  at require (node:internal/modules/helpers:135:16)
                  at Object. (/home/MYMIRR/MagicMirror/js/check_config.js:6:20)
                  at Module._compile (node:internal/modules/cjs/loader:1730:14) {
                  code: ‘MODULE_NOT_FOUND’,
                  requireStack: [ ‘/home/MYMIRR/MagicMirror/js/check_config.js’ ]
                Node.js v22.15.0
                  sdetweil @nowayto
                  @nowayto show me the ~/MagicMirror/installers/upgrade.log
                  note: I had a typo in log filename
                  and then do
                  npm install
                  N 2 Replies Last reply Reply Quote 0
                  • N Offline
                    nowayto @sdetweil
                    Upgrade started - Sat May 10 00:06:51 CEST 2025
                    system is Linux magicmirror2 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                    the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIK>
                    architecture from dpkg is armhf
                    ^[[96mCheck current Node installation …^[[0m
                    ^[[0mNode currently installed. Checking version number.
                    ^[[0mMinimum Node version: ^[[1mv22.14.0^[[0m
                    ^[[0mInstalled Node version: ^[[1mv22.15.0^[[0m
                    ^[[92mNo Node.js upgrade necessary.^[[0m
                    ^[[96mCheck current NPM installation …^[[0m
                    ^[[0mNPM currently installed. Checking version number.
                    ^[[0mMinimum npm version: ^[[1mV10.9.2^[[0m
                    ^[[0mInstalled npm version: ^[[1mV11.3.0^[[0m
                    ^[[92mNo npm upgrade necessary.^[[0m
                    saving custom.css
                    remote name = origin
                    upgrading from version 2.31.0 to 2.31.0
                    fetching latest revisions
                    git fetch rc=0
                    current branch = master
                    On branch master
                    Your branch is up to date with ‘origin/master’.
                    Untracked files:
                    (use “git add …” to include in what will be committed)
                    core
                    errorcal.txt
                    errorcal2.txt
                    errorcal3.txt
                    errorcal4.txt
                    errorcal5.txt
                    nohup.out
                    run-start.sh
                    splashscreen/
                    nothing added to commit but untracked files present (use “git add” to track)
                    no files different from github version
                    • N Offline
                      nowayto @sdetweil
                      @sdetweil npm install results
                      ~/MagicMirror $ npm install
                      npm error code ENOTEMPTY
                      npm error syscall rename
                      npm error path /home/MYMIRR/MagicMirror/node_modules/es-abstract
                      npm error dest /home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi
                      npm error errno -39
                      npm error ENOTEMPTY: directory not empty, rename ‘/home/MYMIRR/MagicMirror/node_modules/es-abstract’ -> ‘/home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi’
                      npm error A complete log of this run can be found in: /home/MYMIRR/.npm/_logs/2025-05-10T06_40_55_661Z-debug-0.log
                      Tried with sudo
                      ~/MagicMirror $ sudo npm install
                      npm error code EBADENGINE
                      npm error engine Unsupported engine
                      npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
                      npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
                      npm error notsup Required: {“node”:“>=22.14.0”}
                      npm error notsup Actual: {“npm”:“11.2.0”,“node”:“v20.18.1”}
                      npm error A complete log of this run can be found in: /root/.npm/_logs/2025-05-10T06_41_52_949Z-debug-0.log
                      npm seems to see an old version of nodejs but:
                      ~/MagicMirror $ node -v
                      v22.15.0
                      I don’t know what happened.
                      If it can help I had first problem after the MMM-SolarPicture
                      but I’ve just installed it and configured it through config.js… nothing more than usual…
                      but the actual behaviour is that pm2 status says it’s running, but on the monitor I see just the raspbian desktop
                      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                      │ 0 │ mm │ default │ N/A │ fork │ 4311 │ 19s │ 64 │ online │ 0% │ 2.6mb │ ber… │ disabled │
                        sdetweil @nowayto
                        @nowayto two things
                        doing test run changes nothing, its a safety check
                        and i wont let you upgrade over the same release accidentally
                        so you need to rerun the command and add
                        force
                        to the end
                        • 1 / 4
