    [ERROR] _ is not defined
    36 Posts 3 Posters 8.8k Views 3 Watching
    • N Offline
      nowayto @sdetweil
      @sdetweil Do you suggest to update manually or auto? Thanks
        sdetweil @nowayto
        @nowayto i never suggest update automatically.
        use my script
        • N Offline
          nowayto @sdetweil
          @sdetweil I’m sorry for the question: that script?
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
            sdetweil @nowayto
            @nowayto yes, but its two steps
            one time without any parameters (test mode)
            and one time with apply
            all you have to do is click/copy the first time and run it
            then do the same on the second if the first ends successfully
            • N Offline
              nowayto @sdetweil
              @sdetweil MM doesn’t work.
              I tried a config check but I have this error now.
              I tried to “npm install eslint -g” but the error persist
              npm run config:check
              magicmirror@2.31.0 config:check
              node js/check_config.js
              node:internal/modules/cjs/loader:1404
              throw err;
              Error: Cannot find module ‘eslint’
              Require stack:
              • /home/MYMIRR/MagicMirror/js/check_config.js
                at Module._resolveFilename (node:internal/modules/cjs/loader:1401:15)
                at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19)
                at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22)
                at Module._load (node:internal/modules/cjs/loader:1211:37)
                at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                at Module.require (node:internal/modules/cjs/loader:1487:12)
                at require (node:internal/modules/helpers:135:16)
                at Object. (/home/MYMIRR/MagicMirror/js/check_config.js:6:20)
                at Module._compile (node:internal/modules/cjs/loader:1730:14) {
                code: ‘MODULE_NOT_FOUND’,
                requireStack: [ ‘/home/MYMIRR/MagicMirror/js/check_config.js’ ]
              Node.js v22.15.0
                sdetweil @nowayto
                @nowayto show me the ~/MagicMirror/installers/upgrade.log
                note: I had a typo in log filename
                and then do
                npm install
                N 2 Replies Last reply Reply Quote 0
                • N Offline
                  nowayto @sdetweil
                  Upgrade started - Sat May 10 00:06:51 CEST 2025
                  system is Linux magicmirror2 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                  the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIK>
                  architecture from dpkg is armhf
                  ^[[96mCheck current Node installation …^[[0m
                  ^[[0mNode currently installed. Checking version number.
                  ^[[0mMinimum Node version: ^[[1mv22.14.0^[[0m
                  ^[[0mInstalled Node version: ^[[1mv22.15.0^[[0m
                  ^[[92mNo Node.js upgrade necessary.^[[0m
                  ^[[96mCheck current NPM installation …^[[0m
                  ^[[0mNPM currently installed. Checking version number.
                  ^[[0mMinimum npm version: ^[[1mV10.9.2^[[0m
                  ^[[0mInstalled npm version: ^[[1mV11.3.0^[[0m
                  ^[[92mNo npm upgrade necessary.^[[0m
                  saving custom.css
                  remote name = origin
                  upgrading from version 2.31.0 to 2.31.0
                  fetching latest revisions
                  git fetch rc=0
                  current branch = master
                  On branch master
                  Your branch is up to date with ‘origin/master’.
                  Untracked files:
                  (use “git add …” to include in what will be committed)
                  core
                  errorcal.txt
                  errorcal2.txt
                  errorcal3.txt
                  errorcal4.txt
                  errorcal5.txt
                  nohup.out
                  run-start.sh
                  splashscreen/
                  nothing added to commit but untracked files present (use “git add” to track)
                  no files different from github version
                  • N Offline
                    nowayto @sdetweil
                    @sdetweil npm install results
                    ~/MagicMirror $ npm install
                    npm error code ENOTEMPTY
                    npm error syscall rename
                    npm error path /home/MYMIRR/MagicMirror/node_modules/es-abstract
                    npm error dest /home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi
                    npm error errno -39
                    npm error ENOTEMPTY: directory not empty, rename ‘/home/MYMIRR/MagicMirror/node_modules/es-abstract’ -> ‘/home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi’
                    npm error A complete log of this run can be found in: /home/MYMIRR/.npm/_logs/2025-05-10T06_40_55_661Z-debug-0.log
                    Tried with sudo
                    ~/MagicMirror $ sudo npm install
                    npm error code EBADENGINE
                    npm error engine Unsupported engine
                    npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
                    npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
                    npm error notsup Required: {“node”:“>=22.14.0”}
                    npm error notsup Actual: {“npm”:“11.2.0”,“node”:“v20.18.1”}
                    npm error A complete log of this run can be found in: /root/.npm/_logs/2025-05-10T06_41_52_949Z-debug-0.log
                    npm seems to see an old version of nodejs but:
                    ~/MagicMirror $ node -v
                    v22.15.0
                    I don’t know what happened.
                    If it can help I had first problem after the MMM-SolarPicture
                    but I’ve just installed it and configured it through config.js… nothing more than usual…
                    but the actual behaviour is that pm2 status says it’s running, but on the monitor I see just the raspbian desktop
                    │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                    │ 0 │ mm │ default │ N/A │ fork │ 4311 │ 19s │ 64 │ online │ 0% │ 2.6mb │ ber… │ disabled │
                      sdetweil @nowayto
                      @nowayto two things
                      doing test run changes nothing, its a safety check
                      and i wont let you upgrade over the same release accidentally
                      so you need to rerun the command and add
                      force
                      to the end
                        @nowayto NEVER use sudo with any npm command
                        the number in the pm2 status 4311 is the number of restarts
                        youve got a mess
                        now we HAVE to use sudo to undo it
                        sudo rm -rf node_modules
                        cd fonts
                        cd ..\vendor
                        sudo rm-rf node_modules
                        cd ..
                        lets see about node
                        which node
                        n
                        q to quit
                        nvm
                        dont do anything else til we figure out the nodejs problem
                        • 1 / 4
