    [ERROR] _ is not defined
    36 Posts 3 Posters 12.7k Views 3 Watching
      sdetweil @nowayto
      @nowayto i never suggest update automatically.
      use my script
      N 1 Reply Last reply
      • N
        nowayto @sdetweil
        @sdetweil I’m sorry for the question: that script?
        bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          sdetweil @nowayto
          @nowayto yes, but its two steps
          one time without any parameters (test mode)
          and one time with apply
          all you have to do is click/copy the first time and run it
          then do the same on the second if the first ends successfully
          • N
            nowayto @sdetweil
            @sdetweil MM doesn’t work.
            I tried a config check but I have this error now.
            I tried to “npm install eslint -g” but the error persist
            npm run config:check
            magicmirror@2.31.0 config:check
            node js/check_config.js
            node:internal/modules/cjs/loader:1404
            throw err;
            Error: Cannot find module ‘eslint’
            Require stack:
            • /home/MYMIRR/MagicMirror/js/check_config.js
              at Module._resolveFilename (node:internal/modules/cjs/loader:1401:15)
              at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19)
              at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22)
              at Module._load (node:internal/modules/cjs/loader:1211:37)
              at TracingChannel.traceSync (node:diagnostics_channel:322:14)
              at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
              at Module.require (node:internal/modules/cjs/loader:1487:12)
              at require (node:internal/modules/helpers:135:16)
              at Object. (/home/MYMIRR/MagicMirror/js/check_config.js:6:20)
              at Module._compile (node:internal/modules/cjs/loader:1730:14) {
              code: ‘MODULE_NOT_FOUND’,
              requireStack: [ ‘/home/MYMIRR/MagicMirror/js/check_config.js’ ]
            Node.js v22.15.0
              sdetweil @nowayto
              @nowayto show me the ~/MagicMirror/installers/upgrade.log
              note: I had a typo in log filename
              and then do
              npm install
              N 2 Replies Last reply
              • N
                nowayto @sdetweil
                Upgrade started - Sat May 10 00:06:51 CEST 2025
                system is Linux magicmirror2 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                the os is PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)” NAME=“Raspbian GNU/Linux” VERSION_ID=“11” VERSION=“11 (bullseye)” VERSION_CODENAME=bullseye ID=raspbian ID_LIK>
                architecture from dpkg is armhf
                ^[[96mCheck current Node installation …^[[0m
                ^[[0mNode currently installed. Checking version number.
                ^[[0mMinimum Node version: ^[[1mv22.14.0^[[0m
                ^[[0mInstalled Node version: ^[[1mv22.15.0^[[0m
                ^[[92mNo Node.js upgrade necessary.^[[0m
                ^[[96mCheck current NPM installation …^[[0m
                ^[[0mNPM currently installed. Checking version number.
                ^[[0mMinimum npm version: ^[[1mV10.9.2^[[0m
                ^[[0mInstalled npm version: ^[[1mV11.3.0^[[0m
                ^[[92mNo npm upgrade necessary.^[[0m
                saving custom.css
                remote name = origin
                upgrading from version 2.31.0 to 2.31.0
                fetching latest revisions
                git fetch rc=0
                current branch = master
                On branch master
                Your branch is up to date with ‘origin/master’.
                Untracked files:
                (use “git add …” to include in what will be committed)
                core
                errorcal.txt
                errorcal2.txt
                errorcal3.txt
                errorcal4.txt
                errorcal5.txt
                nohup.out
                run-start.sh
                splashscreen/
                nothing added to commit but untracked files present (use “git add” to track)
                no files different from github version
                • N
                  nowayto @sdetweil
                  @sdetweil npm install results
                  ~/MagicMirror $ npm install
                  npm error code ENOTEMPTY
                  npm error syscall rename
                  npm error path /home/MYMIRR/MagicMirror/node_modules/es-abstract
                  npm error dest /home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi
                  npm error errno -39
                  npm error ENOTEMPTY: directory not empty, rename ‘/home/MYMIRR/MagicMirror/node_modules/es-abstract’ -> ‘/home/MYMIRR/MagicMirror/node_modules/.es-abstract-fSsKyNTi’
                  npm error A complete log of this run can be found in: /home/MYMIRR/.npm/_logs/2025-05-10T06_40_55_661Z-debug-0.log
                  Tried with sudo
                  ~/MagicMirror $ sudo npm install
                  npm error code EBADENGINE
                  npm error engine Unsupported engine
                  npm error engine Not compatible with your version of node/npm: magicmirror@2.31.0
                  npm error notsup Not compatible with your version of node/npm: magicmirror@2.31.0
                  npm error notsup Required: {“node”:“>=22.14.0”}
                  npm error notsup Actual: {“npm”:“11.2.0”,“node”:“v20.18.1”}
                  npm error A complete log of this run can be found in: /root/.npm/_logs/2025-05-10T06_41_52_949Z-debug-0.log
                  npm seems to see an old version of nodejs but:
                  ~/MagicMirror $ node -v
                  v22.15.0
                  I don’t know what happened.
                  If it can help I had first problem after the MMM-SolarPicture
                  but I’ve just installed it and configured it through config.js… nothing more than usual…
                  but the actual behaviour is that pm2 status says it’s running, but on the monitor I see just the raspbian desktop
                  │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                  │ 0 │ mm │ default │ N/A │ fork │ 4311 │ 19s │ 64 │ online │ 0% │ 2.6mb │ ber… │ disabled │
                    sdetweil @nowayto
                    @nowayto two things
                    doing test run changes nothing, its a safety check
                    and i wont let you upgrade over the same release accidentally
                    so you need to rerun the command and add
                    force
                    to the end
                      @nowayto NEVER use sudo with any npm command
                      the number in the pm2 status 4311 is the number of restarts
                      youve got a mess
                      now we HAVE to use sudo to undo it
                      sudo rm -rf node_modules
                      cd fonts
                      cd ..\vendor
                      sudo rm-rf node_modules
                      cd ..
                      lets see about node
                      which node
                      n
                      q to quit
                      nvm
                      dont do anything else til we figure out the nodejs problem
                      • N
                        nowayto @sdetweil
                        @sdetweil I’m sorry :(
                        I did it what you suggest and config:check gave me a module error again. Different than one before
                        throw err;
                        Error: Cannot find module ‘ajv’
                        Require stack:
                        After “require stack” there are other lines, if you need it, tell me.
                          sdetweil @nowayto
                          @nowayto
                          i said stop
                          we need to fix nodejs so npm install will work
                          node -v
                          says something
                          and npm install says node is different
                          i am trying to figure out where node is installed and by who
                          system, nvm or n
                          you didn’t give me answers to the commands i provided
                          • N
                            nowayto @sdetweil
                            which node gave me
                            /home/MYMIRR/.nvm/versions/node/v22.15.0/bin/node
                            n gave me
                            node/20.18.1
                            Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
                            nvm gave me
                            Node Version Manager (v0.39.5)
                            Note: refers to any version-like string nvm understands. This includes :
                            • full or partial version numbers, starting with an optional “v” (0.10, v0.1.2 , v1)
                            • default (built-in) aliases: node, stable, unstable, iojs, system
                            • custom aliases you define with nvm alias foo
                            followed by a lot of options
                              sdetweil @nowayto
                              @nowayto ok nvm and n do the same function but differently
                              i use n in my scripts because it runs everywhere
                              so lets turn off nvm
                              nvm deactivate
                              nvm unload
                              cd ~
                              rm -rf  .nvm
                              now which node
                              should find /usr/local/bin/node
                              now we need n to get to node 22.14.0
                              sudo n 22.14.0
                              now node -v
                              should return 22.14.0
                              if so, do
                              cd  ~/MagicMirror
                              npm install
                              now MagicMirror should run
                              • N
                                nowayto @sdetweil
                                @sdetweil Thank you a lot Sam.
                                I did everything but
                                I have an [ERROR] _ is not defined
                                magicmirror@2.31.0 start:x11
                                [2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
                                [2025-05-11 15:39:26.527] [LOG] Loading config …
                                [2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
                                [2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
                                [2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
                                [2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
                                [2025-05-11 15:39:28.793] [ERROR] _ is not defined
                                  sdetweil @nowayto
                                  @nowayto so that sounds like the npm install failed again
                                  do it again and show the output
                                  • N
                                    nowayto @sdetweil
                                    installer didn’t failed, but this is the result now
                                    npm install
                                    magicmirror@2.31.0 postinstall
                                    npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                                    magicmirror@2.31.0 install-vendor
                                    echo "Installing vendor files …
                                    " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                    up to date in 7s
                                    magicmirror@2.31.0 install-fonts
                                    echo "Installing fonts …
                                    " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                                    Installing fonts …
                                    up to date in 3s
                                    magicmirror@2.31.0 prepare
                                    [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                    up to date in 45s
                                    285 packages are looking for funding
                                    run npm fund for details
                                      sdetweil @nowayto
                                      @nowayto weird, and npm start fails again _ not defined?
                                      i installed solarpicture without problems
                                      • N
                                        nowayto @sdetweil
                                        I’m sure.I don’t think SolarPicture could be the problem.
                                        Yes, the error keep showing
                                          sdetweil @nowayto
                                          @nowayto wild, lets do this… intall MM again, but save the current…
                                          #backup MM config and modules list
                                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)"
                                          #rename the MagicMirror folder out of the way
                                          cd ~
                                          mv MagicMirror MagicMirror.save
                                          #and install MM again
                                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                          #restore the  MM config and modules
                                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
                                          then
                                          npm start
                                          • N
                                            nowayto @sdetweil
                                            Before writing here I made backups, locally and on github, like you taught me in the past :)
                                            Now I’ll try
