    [ERROR] _ is not defined
    36 Posts 3 Posters 11.9k Views 3 Watching
      @nowayto NEVER use sudo with any npm command
      the number in the pm2 status 4311 is the number of restarts
      youve got a mess
      now we HAVE to use sudo to undo it
      sudo rm -rf node_modules
      cd fonts
      cd ..\vendor
      sudo rm-rf node_modules
      cd ..
      lets see about node
      which node
      n
      q to quit
      nvm
      dont do anything else til we figure out the nodejs problem
      • N Offline
        nowayto @sdetweil
        @sdetweil I’m sorry :(
        I did it what you suggest and config:check gave me a module error again. Different than one before
        npm run config:check
        magicmirror@2.31.0 config:check
        node js/check_config.js
        node:internal/modules/cjs/loader:1404
        throw err;
        Error: Cannot find module ‘ajv’
        Require stack:
        After “require stack” there are other lines, if you need it, tell me.
          sdetweil @nowayto
          @nowayto
          i said stop
          we need to fix nodejs so npm install will work
          node -v
          says something
          and npm install says node is different
          i am trying to figure out where node is installed and by who
          system, nvm or n
          you didn’t give me answers to the commands i provided
          • N Offline
            nowayto @sdetweil
            which node gave me
            /home/MYMIRR/.nvm/versions/node/v22.15.0/bin/node
            n gave me
            node/20.18.1
            Use up/down arrow keys to select a version, return key to install, d to delete, q to quit
            nvm gave me
            Node Version Manager (v0.39.5)
            Note: refers to any version-like string nvm understands. This includes :
            • full or partial version numbers, starting with an optional “v” (0.10, v0.1.2 , v1)
            • default (built-in) aliases: node, stable, unstable, iojs, system
            • custom aliases you define with nvm alias foo
            followed by a lot of options
              sdetweil @nowayto
              @nowayto ok nvm and n do the same function but differently
              i use n in my scripts because it runs everywhere
              so lets turn off nvm
              nvm deactivate
              nvm unload
              cd ~
              rm -rf  .nvm
              now which node
              should find /usr/local/bin/node
              now we need n to get to node 22.14.0
              sudo n 22.14.0
              now node -v
              should return 22.14.0
              if so, do
              cd  ~/MagicMirror
              npm install
              now MagicMirror should run
              • N Offline
                nowayto @sdetweil
                @sdetweil Thank you a lot Sam.
                I did everything but
                I have an [ERROR] _ is not defined
                magicmirror@2.31.0 start:x11
                [2025-05-11 15:39:26.429] [LOG] Starting MagicMirror: v2.31.0
                [2025-05-11 15:39:26.527] [LOG] Loading config …
                [2025-05-11 15:39:26.537] [LOG] config template file not exists, no envsubst
                [2025-05-11 15:39:28.154] [INFO] Checking config file /home/MYMIRR/MagicM irror/config/config.js …
                [2025-05-11 15:39:28.478] [INFO] Your configuration file doesn’t contain syntax errors :)
                [2025-05-11 15:39:28.482] [INFO] Checking modules structure configuration …
                [2025-05-11 15:39:28.793] [ERROR] _ is not defined
                  sdetweil @nowayto
                  @nowayto so that sounds like the npm install failed again
                  do it again and show the output
                  • N Offline
                    nowayto @sdetweil
                    installer didn’t failed, but this is the result now
                    npm install
                    magicmirror@2.31.0 postinstall
                    npm run install-vendor && npm run install-fonts && echo "MagicMirror² installation finished successfully!
                    magicmirror@2.31.0 install-vendor
                    echo "Installing vendor files …
                    " && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    up to date in 7s
                    magicmirror@2.31.0 install-fonts
                    echo "Installing fonts …
                    " && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier
                    Installing fonts …
                    up to date in 3s
                    magicmirror@2.31.0 prepare
                    [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                    up to date in 45s
                    285 packages are looking for funding
                    run npm fund for details
                      sdetweil @nowayto
                      @nowayto weird, and npm start fails again _ not defined?
                      i installed solarpicture without problems
                      • N Offline
                        nowayto @sdetweil
                        I’m sure.I don’t think SolarPicture could be the problem.
                        Yes, the error keep showing
                          sdetweil @nowayto
                          @nowayto wild, lets do this… intall MM again, but save the current…
                          #backup MM config and modules list
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)"
                          #rename the MagicMirror folder out of the way
                          cd ~
                          mv MagicMirror MagicMirror.save
                          #and install MM again
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                          #restore the  MM config and modules
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)"
                          then
                          npm start
                          N 2 Replies Last reply Reply Quote 0
                          • N Offline
                            nowayto @sdetweil
                            Before writing here I made backups, locally and on github, like you taught me in the past :)
                            Now I’ll try
                            • N Offline
                              nowayto @sdetweil
                              That’s incredible… I did it, everything goes good… no issues but when I start it
                              npm start
                              npm run start:x11
                              [2025-05-11 22:44:21.593] [LOG] Starting MagicMirror: v2.31.0
                              [2025-05-11 22:44:21.682] [LOG] Loading config …
                              [2025-05-11 22:44:21.687] [LOG] config template file not exists, no envsubst
                              [2025-05-11 22:44:23.250] [INFO] Checking config file /home/MYMIRR/MagicMirror/config/config.js …
                              [2025-05-11 22:44:23.532] [INFO] Your configuration file doesn’t contain syntax errors :)
                              [2025-05-11 22:44:23.535] [INFO] Checking modules structure configuration …
                              [2025-05-11 22:44:23.824] [ERROR] _ is not defined
                              Again this _ is not defined
                                sdetweil @nowayto
                                @nowayto wow!!! NOW i am really confused.
                                have you rebooted?
                                if you try the sample config.js
                                cd ~/MagicMirror/config
                                mv config.js config.js.save
                                cp config.js.sample config.js
                                and then
                                npm start
                                does it run or fail
                                • N Offline
                                  nowayto @sdetweil
                                  Sam… I don’t know how to saying it.
                                  I figure out the issue.
                                  After your last message I tried what you suggest.
                                  With the default cfg I had no errors, with mine I had errors.
                                  So I checked again and again the config…
                                  and I find an underscore _ right at the start of the config
                                  npm config:check told me “no syntax errors” and that confusing me.
                                  When I edit it I use nano editor
                                  I do “sudo nano config.js” and I press CTRL + _ to jump at the 250 line.
                                  Might be one of the latest time I opened it and press _ a bit faster than CTRL and I add it for error.
                                  In addition I notice that when I open config.js with nano editor the green cursor is, clearly, at the start of the first line… EXACTLY on the undescore _ and it hides it.
                                  I’m really sorry for bothering you with that.
                                  How can I buy you a coffee ?
                                    sdetweil @nowayto
                                    @nowayto no coffee needed, we found it!!!
                                    please NEVER use sudo inside MagicMirror folder
                                    no reason to use super user , just makes trouble later
                                    so if you fix the config.js in the saved MagicMirror folder then it should run ok too!!!"
                                    ill see what we can do about the misleading message… thanks for your energy here!!!
                                    S N 3 Replies Last reply Reply Quote 0
                                      @nowayto i use ctrl-end on my keyboard for nano to get to end of file
                                      haven’t found a way to do that on my chromebook, drives me crazy!!!
                                        @nowayto ok, I’ve found the error producer
                                        and I’ll propose a fix…
                                        I think this might have been more useful lol
                                        [ERROR] fatal error in /home/sam/MagicMirror/config/config.js at line 19 column 1,  _ is not defined
                                        I opened
                                        https://github.com/MagicMirrorOrg/MagicMirror/issues/3785
                                        for this issue
                                        • N Offline
                                          nowayto @sdetweil
                                          @sdetweil Ok but I wanna just offer a coffe for your kind and your time spent with that.
                                          Do you suggest me to fix the old magic mirror folder or just rm it?
                                            sdetweil @nowayto
                                            @nowayto if you have everything working, you can rm it
                                            i was just saying you could prove this change would fix the prior install
                                            i do this for fun, really! pay it forward, help someone else on whatever when you can.
