    PM2 for server mode
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    4 Posts 2 Posters 3.0k Views 2 Watching
    • sifuhallS
      sifuhall
      What must I do to use pm2 to launch in server mode at boot?
      My eventual goal is to have multiple instances running server mode on multiple ports. As I understand it I need to copy the MagicMirror directory for each instance and change ports.
      But how can I launch them at boot with PM2?
      Thank you!
        sdetweil @sifuhall
        @sifuhall
        change the command in the script pm2 starts
        as for multiple instances you can do it all from one folder
        use the MM_CONFIG_FILE environment variable
        and maybe MM_PORT variable
        see
        https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples
        you can start them all in one script, but hard to stop
        they can all use the same config file and use MM_PORT to
        override what is in the config file
        or use a different config file too
        you can install all modules in the one folder
        and use different modules in different instances
        npm run server
        instead of
        npm run start
        then
        pm2 start server1.sh
        pm2 start server2.sh
        etc
        pm2 save
        pm2 status should show them running
        reboot
        sifuhallS 1 Reply Last reply Reply Quote 1
        • sifuhallS
          sifuhall @sdetweil
          @sdetweil Thank you!
            sdetweil @sifuhall
            @sifuhall one thing
            pm2’s job is to keep the app running. so when the script ends it restarts
            in windows to spin off a separate task you use detach
            detach xxxx.bat
            in
            linux you use the & as last character
            xxx.sh &
            so if you choose to launch from one script
            # use port in config.js
            npm run server &
            # override port in config.js
            export MM_PORT=8090
            npm run server &
            export MM_PORT=8100
            npm run server &
            there is nothing to keep the script running
            and pm2 will relaunch it
            just remove the last &
            and bash will wait for that command to end(never)
            pm2 will be happy
