    MMM-Universal-Pir issues
    6 Posts 4 Posters 990 Views 4 Watching
    • E Offline
      eyesallin
      Hi
      Apologies I’m a complete noob.
      I’ve been using the old MMM-PIR but now I’ve updated to the latest software it stopped working.
      I have now in stalled MMM-Universal-Pir, the countdown works fine but when it hits zero the screen stays on, the pir can be reset but each it hits zero it just stays on.
      Can someone tell me what I’m doing wrong?
        rkorell Module Developer @eyesallin
        @eyesallin ,
        MMM-Universal-Pir needs correct configuration for the screen-on / screen-off commands.
        These commands are dependant of your Pi-Model and OS.
        The default is for bookworm/wayland config.
        If your Pi differs you need the correct command.
        For older OS versions this are commands with xrandr …
        Good luck.
        Regards,
        Ralf
        • E Offline
          eyesallin
          Hi Ralf
          Thank for responding.
          I am using a PI 5 with Linux bookworm
          How do i go about configuring the commands.
          Regards
          Gary
          S R 2 Replies Last reply Reply Quote 0
            sdetweil @eyesallin
            @eyesallin the module provides config options, see the readme
              OK, with Pi5/bookworm the wayland standard config should work…
              Or do you have re-configured to X11?
              You can check right syntax for your system by trial&error on commandline in terminal window.
              If you are working headless (remote terminal) you have to place a „DISPLAY:0“ in front of the command you are trying…
              Regards,
              Ralf
                Mawgli
                The module is working. After the set time, the screen turns off. But after about 10 seconds, the screen turns on. The counter shows 0 seconds.
