    v2.32.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 998 Views 1 Watching
    • karsten13K Offline
      karsten13
      [2.32.0] - 2025-07-01
      Thanks to: @bughaver, @bugsounet, @khassel, @KristjanESPERANTO, @plebcity, @rejas, @sdetweil.
      ⚠️ This release needs nodejs version v22.14.0 or higher
      ⚠️ This release uses express v5 which has breaking changes that may cause problems with third-party modules
      Added
      • [config] Allow to change module order for final renderer (or dynamically with CSS): Feature order in config (#3762)
      • [clock] Added option ‘disableNextEvent’ to hide next sun event (#3769)
      • [clock] Implement short syntax for clock week (#3775)
      Changed
      • [refactor] Simplify module loading process (#3766)
      • Use node --run instead of npm run (#3764) and adapt start:dev script (#3773)
      • [workflow] Run linter and spellcheck with LTS node version (#3767)
      • [workflow] Split “Run test” step into two steps for more clarity (#3767)
      • [linter] Review linter setup (#3783)
        • Fix command to lint markdown in CONTRIBUTING.md
        • Re-activate JSDoc linting and fix linting issues
        • Refactor ESLint config to use defineConfig and globalIgnores
        • Replace eslint-plugin-import with eslint-plugin-import-x
        • Switch Stylelint config to flat format and simplify Stylelint scripts
      • [workflow] Replace Node.js version v23 with v24 (#3770)
      • [refactor] Replace deprecated constants fs.F_OK and fs.R_OK (#3789)
      • [refactor] Replace ansis with built-in function util.styleText (#3793)
      • [core] Integrate stuff from vendor and fonts folders into main package.json, simplifies install and maintaining dependencies (#3795, #3805)
      • [l10n] Complete translations (with the help of translation tools) (#3794)
      • [refactor] Refactored calendarfetcherutils in Calendar module to handle timezones better (#3806)
        • Removed as many of the date conversions as possible
        • Use moment-timezone when calculating recurring events, this will fix problems from the past with offsets and DST not being handled properly
        • Added some tests to test the behavior of the refactored methods to make sure the correct event dates are returned
      • [linter] Enable ESLint rule no-console and replace console with Log in some files (#3810)
      • [tests] Review and refactor translation tests (#3792)
      Fixed
      • [fix] Handle spellcheck issues (#3783)
      • [calendar] fix fullday event rrule until with timezone offset (#3781)
      • [feat] Add rule no-undef in config file validation to fix #3785 (#3786)
      • [fonts] Fix roboto.css to avoid error message Unknown descriptor 'var(' in @font-face rule. in firefox console (#3787)
      • [tests] Fix and refactor e2e test Same keys in translations_spec.js (#3809)
      • [tests] Fix e2e tests newsfeed and calendar to exit without open handles (#3817)
      Updated
      • [core] Update dependencies including electron to v36 (#3774, #3788, #3811, #3804, #3815, #3823)
      • [core] Update package type to commonjs
      • [logger] Review factory code part: use switch/case instead of if/else if (#3812)
      https://github.com/MagicMirrorOrg/MagicMirror/releases/tag/v2.32.0
      • karsten13K karsten13 locked this topic on
