    Sonos Module
    18 Posts 7 Posters 10.8k Views 6 Watching
    • SnilleS Offline
      Snille Module Developer @Atreo
      @Atreo Hehe, yes. But let’s keep it to English anyway. :)
      You are using my “fork” of the “MMM-Sonos” right, if not some of the config-stuff will not work. :)
      This is my fork: https://github.com/Snille/MMM-Sonos
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        Dicous
        Can someone please share a working config? Please ^^
        My following does not work:
        module: 'MMM-Sonos',
        	header: "Playing on SONOS",
        	classes: "default everyone",
        				apiBase: "http://localhost",
        				apiPort: 5005,
        				showAlbumArt: true,
        				showRoomName: true,
        				showPausedZone: false,
        				showStoppedRoom: false,
        				preRoomText: 'Raum: ',
        				preArtistText: 'Artist: ',
        				preTrackText: 'Lied: ',
        				preTypeText: 'Quelle: ',
        				animationSpeed: 1000,
        				apiEndpoint: "zones",
        				exclude: []
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS Offline
          Snille Module Developer @Dicous
          @Dicous What happens, what does not work?
            Dicous
            There is always the “Loading music …”
            • SnilleS Offline
              @Dicous Do you get the “zones” when you check the sonos-web-api? If you have it on the mirror: http://the-ip-to-your-mirror:5005/zones
              You should get a list of all the zones and lot’s of data from the sonos-web-api.
              luisestradaL 1 Reply Last reply Reply Quote 0
              • thymonT Offline
                thymon
                This post is deleted!
                • luisestradaL Offline
                  luisestrada @Snille
                  • Thorn2910T Offline
                    Thorn2910
                    I had exactly the same issue!
                    MMM-Sonos Version v.0.0.1 released beginning of 2024
                    Chnged in MMM-Sonos.js th following part
                    from
                    apiBase: 'http://localhost',
                    to
                    apiBase: 'http://192.168.1.22',
                    Obviously change the IP addess accordingly
                    For additional info my MMM-Sonos part config.js in /MagicMirror/config/config.js
                                            //header: "Sonos",
                                            position: 'top_center', // you may choose any location
        albumArtLocation: "left",
                    then it worked! With http://localhost I always got
                    [ERROR] Failure: Error: connect ECONNREFUSED ::1:5005
                    in the logs
