    MMM-WhisperGPD ERRORS
    1 Posts 1 Posters 786 Views 1 Watching
    • A
      Anthony Project Sponsor
      Hello everyone. I installed MMM-WhisperGPD but I am keep getting some errors whatever I do. I am not familiar with coding so I am trying everything I find in the web. Below are the errors:
      0|mm  | [2025-07-28 20:39:44.253] [ERROR] (node:183837) UnhandledPromiseRejectionWarning: Error: PvRecorder failed to initialize.
      0|mm  |     at pvRecorderStatusToException (/home/anthonypi/MagicMirror/modules/MMM-WhisperGPT/node_modules/@picovoice/pvrecorder-node/dist/errors.js:35:20)
      0|mm  |     at new PvRecorder (/home/anthonypi/MagicMirror/modules/MMM-WhisperGPT/node_modules/@picovoice/pvrecorder-node/dist/pv_recorder.js:45:40)
      0|mm  |     at Class.setupAudioRecorder (/home/anthonypi/MagicMirror/modules/MMM-WhisperGPT/node_helper.js:75:22)
      0|mm  |     at Class.socketNotificationReceived (/home/anthonypi/MagicMirror/modules/MMM-WhisperGPT/node_helper.js:44:12)
      0|mm  |     at Socket.<anonymous> (/home/anthonypi/MagicMirror/js/node_helper.js:91:10)
      0|mm  |     at Socket.onevent (/home/anthonypi/MagicMirror/node_modules/socket.io/dist/socket.js:462:26)
      0|mm  |     at Socket._onpacket (/home/anthonypi/MagicMirror/node_modules/socket.io/dist/socket.js:430:22)
      0|mm  |     at /home/anthonypi/MagicMirror/node_modules/socket.io/dist/client.js:214:24
      0|mm  |     at process.processTicksAndRejections (node:internal/process/task_queues:85:11)
      0|mm  | (Use `electron --trace-warnings ...` to show where the warning was created)
      0|mm  | [2025-07-28 20:39:44.253] [ERROR] (node:183837) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      Any help apreciated. Thanks in advance.
