    MMM-calendarExt3 filter agendas
    11 Posts 3 Posters 1.5k Views 3 Watching
      redux703
      Hello,
      I have multiple pages with calendars, is it possible to filter it? So:
      Page 0, all agenda’s
      Page 1, person 1
      Page 2, person 2
      Page 3, person 3
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @redux703
        @redux703 ext3 has a filter capability
        see the readme
        • BKeyportB Offline
          BKeyport Module Developer @redux703
          @redux703 Assuming each person has a separatee calendar, there’s the “calendarset” keyword.
          If not https://github.com/MMRIZE/MMM-CalendarExt3?tab=readme-ov-file#filtering
          Very powerful. Once you have a base idea, we’ll help write the filters if you can’t get it…
            redux703 @BKeyport
            @BKeyport
            Yeah the calendarSet: (‘’) worked so far. But for some reason it gives two strange errors:
            1, it is now (2025-08-01), and the month calendar shows 2025-09-01, and the week calender is still right.
            2, for some reason, there are some dates that get mixed up. For example: someones birthday that is in December, now shows on July, while the same day. The month is different.
              sdetweil @redux703
              @redux703
              if you show the default calendar do these date issues appear there?
                redux703 @sdetweil
                Yep it still shows there.
                While in the source agenda (google calendar on the phone etc) it is still correct. It also seems only to happen with “jarig” in the title. But some are also correct
                  sdetweil @redux703
                  @redux703 ok, can you provide an event entry from the ical data?
                  this part of the default cal has just been rewritten
                  we need to open an issue on the MagicMirror github page
                    redux703 @sdetweil
                    How can i do that?
                      sdetweil @redux703
                      @redux703
                      to get the cal in text do
                      curl -sL your-cal-url > somefile.txt
                      the cal is just a text file
                      edit with genie, nano, whatever you are comfortable with
                      find the event entry THAT
                      BEGIN:VEVENT
                      END:VEVENT
                      dont delete any lines, but you can xxx out whatever
                      dont change the uid line
                        redux703 @sdetweil
                        @sdetweil hey the error was probably comming from the agenda it self… it was put in the samsung agenda app, which would add it to the hotmail calemdar that would sync with google agenda.
                        The only problem i now still have is the calendarSet.
                        It still doesnt filter out the calendars i dont want…
                          sdetweil @redux703
                          @redux703 calendarSet should only pick the different default calendar (s)
                          the filter function allows you to check different event characteristics, title, date…
                          • R redux703 has marked this topic as solved on
