    Cannot access mirror
    9 Posts 2 Posters 1.2k Views 2 Watching
    • R
      rkorell Module Developer
      Good mornning,
      Desparately asking you guys:
      Since yesterday I cannot access my mirror remotely anymore….
      Network outgoing seems to work: All modues are showing their actual data.
      Currently even web access is possible (browser access).
      I have a modue showing internet access/IP onscreen, both greeen and valid.
      But I cannot access via: VNC and (more urgent) terminal (ssh) as well as ftp (this as sftp).
      Any idea?
      (Pi5 on Pi power supply 27W & no SD card but NVME with 16/228GB used).
      Power supply pretty new but just ordered a new one …
      Thanks for any suggestion!
      Warmest regards,
      Ralf
      • R
        @sdetweil ,
        ps -ef | grep ssh
        edit: fixed command above
        doesn’t work…
        As you can read from this statement: I’m now able to connect and this is remotely …
        It SEEMS I’ve identified the root cause (I’m not that sure but connection is stable longer than the last times. I’s pretty slow but doesn’t disconnect nearly immediatly).
        I’v just a little bit disassebled and connected another power supply …
        This currently fixes issues …
        Be curious how long this lasts…
        But because ssh as well as VNC were disconnected - insufficient power was the most probable explanation
        (despite I doesn’t have ANY clue why this happens! The power supply is 6months old and I cannot imagine any reason why “insufficient” power causes this behaviour: only disrupt “ingoing” requests…
        • If anybody have an idea - highly welcome!!!)
          sdetweil @rkorell
          @rkorell what changed?
          you said web access from pi to outside, or from another machine to pi?
          • R
            @sdetweil web access e.g. from phone or tablet to pi …
              sdetweil @rkorell
              @rkorell did the PI address change from yesterday?
              if you can get on the machine desktop and open a terminal,
              ps -ef | ssh
              to see if ssh server is running…
              R 2 Replies Last reply Reply Quote 0
              • R
                @sdetweil I‘ve rebooted several times. Sometimes I can get access for a very short time after a reboot, get disconnect and after disconnect not able to re-connect…
                IP is always the same - fixed in router.
                So: really strange …
                Shell access currently not possible, so no testing, sorry. Mirror has to be disassebled - which I can perform earliest tomorrow, because I‘m on the road…
                Regards,
                Ralf
                • R
                  @sdetweil ,
                  ps -ef | grep ssh
                  doesn’t work…
                  • R rkorell has marked this topic as solved on
                    sdetweil @rkorell
                    @rkorell wild. ive only had one powersupply fail in 8 yrs
                    interesting side effect
                    your “doesn’t work” on the ps -ef
                    means that sshd was not running
                    • R
                      @sdetweil …
                      ps -ef | ssh
                      usage: ssh [-46AaCfGgKkMNnqsTtVvXxYy] [-B bind_interface]
                                 [-b bind_address] [-c cipher_spec] [-D [bind_address:]port]
                                 [-E log_file] [-e escape_char] [-F configfile] [-I pkcs11]
                                 [-i identity_file] [-J [user@]host[:port]] [-L address]
                                 [-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port]
                                 [-Q query_option] [-R address] [-S ctl_path] [-W host:port]
                                 [-w local_tun[:remote_tun]] destination [command [argument ...]]
                      I guess you’ve meant a kind of grep …
                      From my (very basic) understanding your command tries to pipe process list to ssh …
                      BTW: confirmed. Switching the power supply eliminates failure…
                      I’m connected whol day long …
                      Warmest regards,
                      Ralf
                        sdetweil @rkorell
                        @rkorell yes meant grep ssh
                        good info on ps failure impacts
