    Reoccurring events wrong time MyCalendar
    7 Posts 2 Posters 2.5k Views 2 Watching
      rnieto18
      Anyone else having issues with reoccurring calendar events and MyCalendar. When my calendar has a one time event. The time is correct. If there is reoccurring events, the times are about six hours off. Has anybody else had this happen?
        rnieto18 @sdetweil
        @sdetweil Hey thank you for the help, I was out and about all day and just now able to look at the module. Its not my module I found it on the old list of modules from the main page a while back.
        I switched back to the original and its not having the same time issue. I checked and the module isn’t listed on the new list of modules so I will reach out through the github to the creator as well.
        Again thank you for the help!
          sdetweil @rnieto18
          @rnieto18 what is MyCalendar? a module
          can you show the source
          git remote -v
          in the module folder
            rnieto18 @sdetweil
            @sdetweil Sorry yes I am using MMM-MyCalendar.
            https://github.com/dbeltjr/MMM-MyCalendar.git
            I did check the github for any issues but I figured since its based off the default calendar it maybe something others have addressed.
              sdetweil @rnieto18
              @rnieto18 is this your calendar? created by what source?
              this module reads the cal event entries and processes them itself.
              the default module has also seen problems…
              if you use that cal module temporarily, do you see the same issue?
              module:“calendar”
                rnieto18 @sdetweil
                  rnieto18 @rnieto18
                  I found out that it has to do with timezones for reoccuring events not getting set. For anyone looking at this later
                    sdetweil @rnieto18
                    @rnieto18 thanks for the feedback
