    MMM-ImagesPhotos
    6 Posts 2 Posters 3.2k Views 2 Watching
    • N Offline
      Nneuland
      My favorite module by far. Confusing thing happened, I noticed because of schedule, I’m seeing the same images every day. I decided to change the sequential setting to false in config. Unfortunately, this has changed nothing and they are still in the same order.
      Any suggestions on what might be happening?
      Thanks all
      Nick
        sdetweil @Nneuland
        @Nneuland no idea, I use it all the time and have sequential false…
          sdetweil @Nneuland
          @Nneuland how many images?
          the algoritm use in IP is
          Math.floor(Math.random() * photos.length);
          math random is 0-1
          math floor rounds up (>0)
          it needs an whole number cause there is a 0-(num-1) list of images to pick
          so the smaller the list the more common the results will be
          I have about 150 images
          • N Offline
            Nneuland @sdetweil
            I have quite a few images. 260 i think. I suppose i could write a script to rename my images randomly as a work around. but we just curious if anyone has similar issues.
            thanks
            S N 2 Replies Last reply Reply Quote 0
              sdetweil @Nneuland
              @Nneuland has nothing to do with the names…
              its purely count
              you could write quick js to test the results with 260 images
               let num_images=260
               const generate = () => Math.floor(Math.random() * num_images);
               let hash={}
               for(let i =0; i<num_images; i++){
               	 let t=generate()
                 console.log("iteration ",i ," index ",t )
                 if(hash[t]===undefined)
                 	hash[t]=0
                 hash[t]++
               console.log("starting hash dump")
               	if(hash[i] === undefined)
               		console.log("found unused    at "+i)
               	else if(hash[i]===1)
               		console.log("found 1 use     at "+i)
               	else if(hash[i]>1)
               		console.log("found recurring at "+i)
               console.log("done with hash dump")
              there were dups, and unused
              • N Offline
                Nneuland @Nneuland
                @sdetweil I’ll try that out. Thank you Sam!
