    Enhancing MagicMirror with Acrylic Panel Lighting & Custom Fabrication Ideas
    2 Posts 2 Posters 3.9k Views 2 Watching
    • C
      charlenesays
      Hi everyone,
      I’m working on upgrading my MagicMirror build and would love your thoughts & advice. I want to integrate acrylic panels with edge lighting behind the mirror frame, along with some custom fabrication to make it look sleek and modern.
      Here’s what I’m thinking:
      • Use ⅛-inch or ¼-inch acrylic strips cut to size, possibly with custom engraving or patterns to diffuse the LED edge lighting.
      • Build a frame or housing that hides LEDs well, protects against dust, and allows easy access for maintenance.
      • Explore materials like acrylic, PETG, or polycarbonate for durability and clarity.
      • Trying to decide between laser cutting vs CNC routing vs buying prefabricated pieces.
      Specifically, I’d love help with:
      • What acrylic thickness works best for edge lighting without too much diffusion or glare?
      • Recommended types of LED strips (color temp, brightness) that pair well with acrylic edges.
      • Tips for fabricating the frame—mounting techniques, matching finish, and minimizing visible seams or hardware.
      • Any shops or services you’ve used for custom plastic fabrication (laser/CNC) for mirror builds?
      I’ve done some acrylic work with custom fabrication offerings and want to level up the aesthetics and functionality. Happy to share sketches and photos as it evolves!
      Thanks in advance for any input or examples you’ve done.
        sdetweil @charlenesays
        @charlenesays where in the world are you?
