    MagicMirror problem
    7 Posts 4 Posters 2.8k Views 4 Watching
    • T Offline
      tonyarogers
      Hello,
      I’m having trouble starting my magic mirror. When I power it on, the screen goes white, then turns black and stays that way. I also encounter these two errors when I run the “npm start” command:
      [1781:0729/182107.882259:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path=/org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
      [2024-07-29 18:21:40.316] [LOG] Launching application.
      [1781:0729/182305.510139:ERROR:network_service_instance_impl.cc(600)] Network service crashed, restarting service.
      I’ve tried everything but still can’t find a solution. Can anyone help me? I’m running it on a Raspberry Pi 3A+ with 64-bit Pi OS. Thanks in advance!
      S BKeyportB karsten13K 3 Replies Last reply Reply Quote 0
        sdetweil @tonyarogers
        @tonyarogers this sounds like an sd card failure.
        How long ago did you build this setup?
        3A is a very old setup
        • BKeyportB Offline
          BKeyport Module Developer @tonyarogers
          @tonyarogers Time to update your hardware and/or create a new SD Card for it.
          • T Offline
            tonyarogers @sdetweil
            @sdetweil said in MagicMirror problem:
            I built this setup a week ago
              @tonyarogers hmmm
              Let’s try this
              Change your config.js
              address:”0.0.0.0”,
              ipWhitelist:[],
              Then
              npm run server
              Instead of npm start
              Then use another system, phone to connect to that pi
              http://pi-address:8080
              • karsten13K Offline
                karsten13 @tonyarogers
                @tonyarogers said in MagicMirror problem:
                I had similar problems with a setup on a pi zero 2w.
                The pi 3A+ seems to have the same memory of only 512 MB.
                Short story: The os and the dependencies of mm (node and electron) seems to need more memory with every new version. I gave up with such hardware.
                It is not impossible to get it running with increasing swap size or using 32-bit os but it is a dead end …
                • T Offline
                  Let’s try this
                  address:”0.0.0.0”,
                  ipWhitelist:[],
                  Then
                  npm run server
                  http://pi-address:8080 geometry dash scratch
                  Thanks for your suggestion. I got it.
