    MagicMirror problem
    7 Posts 4 Posters 2.6k Views 4 Watching
    • BKeyportB Offline
      BKeyport Module Developer @tonyarogers
      @tonyarogers Time to update your hardware and/or create a new SD Card for it.
      • T Offline
        tonyarogers @sdetweil
        @sdetweil said in MagicMirror problem:
        this sounds like an sd card failure.
        How long ago did you build this setup?
        3A is a very old setup
        I built this setup a week ago
          sdetweil @tonyarogers
          @tonyarogers hmmm
          Let’s try this
          Change your config.js
          address:”0.0.0.0”,
          ipWhitelist:[],
          Then
          npm run server
          Instead of npm start
          Then use another system, phone to connect to that pi
          http://pi-address:8080
          • karsten13K Offline
            karsten13 @tonyarogers
            @tonyarogers said in MagicMirror problem:
            Network service crashed
            I had similar problems with a setup on a pi zero 2w.
            The pi 3A+ seems to have the same memory of only 512 MB.
            Short story: The os and the dependencies of mm (node and electron) seems to need more memory with every new version. I gave up with such hardware.
            It is not impossible to get it running with increasing swap size or using 32-bit os but it is a dead end …
            • T Offline
              Let’s try this
              address:”0.0.0.0”,
              ipWhitelist:[],
              Then
              npm run server
              http://pi-address:8080 geometry dash scratch
              Thanks for your suggestion. I got it.
