    v2.33.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 2.0k Views 1 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer
      [2.33.0] - 2025-10-01
      Thanks to: @Crazylegstoo, @dathbe, @m-idler, @plebcity, @khassel, @KristjanESPERANTO, @rejas and @sdetweil!
      ⚠️ This release needs nodejs version v22.18.0 or higher
      Added
      • Add configuration option for User-Agent, used by calendar & news module (#3255)
      • [linter] Add prettier plugin for nunjuck templates (#3887)
      • [core] Add clear log for occupied port at startup (#3890)
      Changed
      • [clock] Add CSS to prevent line breaking of sunset/sunrise time display (#3816)
      • [core] Enhance system information logging format and include additional env and RAM details (#3839, #3843)
      • [refactor] Add new file js/module_functions.js to move code used in several modules to one place (#3837)
      • [refactor] Use global.root_path where possible and add tests for config:check (#3883, #3885, #3886, #3889)
      • [tests] refactor: simplify jest config file (#3844)
      • [tests] refactor: extract constants for weather electron tests (#3845)
      • [tests] refactor: add setupDOMEnvironment helper function to eliminate repetitive JSDOM setup code (#3860)
      • [tests] replace console with Log in calendar debug.js to avoid exception in eslint config (#3846)
      • [tests] speed up e2e tests, cleanup and stabilize weather e2e tests, update snapshot url (#3847, #3848, #3861)
      • [tests] refactor translation tests (#3866)
        • Remove sinon dependency in favor of Jest native mocking
        • Unify test helper functions across translation test suites
        • Rename setupDOMEnvironment to createTranslationTestEnvironment for consistency
        • Simplify DOM setup by removing unnecessary Promise/async patterns
        • Avoid potential port conflicts by using port 3001 for translator unit tests
        • Improve test reliability and maintainability
      • [tests] add alert module tests for different welcome_message configurations (#3867)
      • [lint-staged] use prettier --write --ignore-unknown in lint-staged to avoid errors on unsupported files (#3888)
      Updated
      • [calendar] Update defaultSymbol name and also the link to the icon search site (#3879)
      • [core] Update dependencies including electron to v38 as well as github actions (#3831, #3849, #3857, #3858, #3872, #3876, #3882, #3891, #3896)
      • [weather] Update feels_like temperature calculation formula (#3869)
      • [weather] Update null value handling for weather type (#3892)
      • [layout] Update styles for weather and calendar (#3894)
      Fixed
      • [calendar] Fixed broken unittest that only broke on the 1st of July and 1st of january (#3830)
      • [clock] Fixed missing icons when no other modules with icons is loaded (#3834)
      • [weather] Fixed handling of empty values in weathergov providers handling of precipitationAmount (#3859)
      • [calendar] Fix regression handling of limit days (#3840)
      • [calendar] Fixed regression of calendarfetcherutils.shouldEventBeExcluded (#3841)
      • [core] Fixed socket.io timeout when server is slow to send notification, notification lost at client (#3380)
      • [tests] refactor AnimateCSS tests after jsdom 27 upgrade (#3891)
      • [weather] Use apparent_temperature data from openmeteo’s hourly weather for current feelsLikeTemp (#3868).
      • [weather] Updated envcanada Provider to use new database/URL schema for accessing weather data (#3878).
      • karsten13K karsten13 locked this topic on
