Navigation
    • Search
    Wake up the mirror and put it to sleep?
    Hardware
    3832
    • W
      wizz last edited by
      I just wounder as i want to have a touch sensor of some kind when i get to the mirror i just touch the sensor and the screen wakes up and also when leaving the mirror in the same way just tap and it go back to sleep.
      What do i need (Hardware) for that and is that possible and how do i do that settings?
      The mirror also have to be scheduled for some times during the day how do i do that?
      • W
        wizz last edited by
        No one have any tips on solution for this?
        broberg 1 Reply Last reply Reply Quote 0
        • broberg
          broberg Project Sponsor @wizz last edited by
          @wizz set up a chronjob in linux and maybe use MMM-Button for the touch?
          • M
            mortenbirkelund last edited by
            This module is what you need. Along with one of the pir sensors, as linked to in the readme.
            https://github.com/paviro/MMM-PIR-Sensor
            If you dont want it to start everytime you pass by your mirror, then you just place the sensor pointing up or down, and then you change swipe your hand in front of the sensor to activate the mirror.
            • W
              wizz last edited by
              Thanks will check if i can get hold of one in a store i Sweden today, if not i have to make an order online.
              • M
                If you cant find one in sweden, then I use to order from thePiHut as it is located within the EU and therefore free from import tax, (atleast until Brexit)
                https://thepihut.com/pages/search-results?q=pir&page_num=4,
                • W
                  wizz last edited by
                  This one will that work?
                  https://www.kjell.com/se/sortiment/el-verktyg/elektronik/arduino/moduler/rorelsedetektor-for-arduino-p87892
                  • M
                    yes, i believe it should work along with a raspberry pi.
                    • W
                      wizz last edited by
                      @mortenbirkelund will check at home first as i bought me lots of things to my Arduino a while ago, and see if I might have one at home 🙂
