    Performances on Pi 3A+
    9 Posts 2 Posters 1.4k Views 2 Watching
    • N
      nowayto
      Hello,
      I’m here to asking an help.
      In the past I’ve set up an MM and it works good.
      I started using a PI 3A+ with 512mb of ram, after some months and some performance issues I switched it to a pi 3B+ with 1GB of ram.
      Honestly performance’s issues were not ram related, because the command “free” told me I have a lot of free mem but I switched anyway for “science purpose”
      Anyway, on pi 3B+ it worked better.
      After some months I decided to turn it back on a 3A+ for some reasons.
      The 3B+ with a lot of ports is wasted on that project, 3A+ should be enuough and I’m right but some little problems appeared again.
      Tha major problem is at startup: sometimes it started with a black screen and cursor and I need to manually CTRL+R to make the interface show correctly.
      It’s very strange, in my limited mind an issue like that is related to RAM but is not.
      “Free” shows me a good amount of Free RAM.
        sdetweil @nowayto
        @nowayto can you show the output of MagicMirror startup?
        Are you using pm2 to launch MagicMirror?
        Can you show the output of free -m
        • N
          nowayto @sdetweil
          @sdetweil Yes, I’m using PM2
                         total        used        free      shared  buff/cache   available
          Mem:             427         174          82           1         170         200
          Swap:           1023         145         878
            sdetweil @nowayto
            @nowayto while MagicMirror is running
            • N
              nowayto @sdetweil
              it’s running
              pm2 status
              │ id │ name   │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
              │ 1  │ mag    │ default     │ N/A     │ fork    │ N/A      │ 0      │ 1    │ stopped   │ 0%       │ 0b       │ ber… │ disabled │
              │ 0  │ mm     │ default     │ 2.31.0  │ fork    │ 781      │ 55m    │ 0    │ online    │ 0%       │ 808.0kb  │ ber… │ disabled │
              free -m
              Mem:             427         149          78          29         199         196
              Swap:           1023         178         845
                sdetweil @nowayto
                @nowayto never seen such a low memory use!!!
                • N
                  nowayto @sdetweil
                  @sdetweil it’s strange… because I have some modules active
                  standard Calendar
                  MMM-CalendarEXT3
                  standard weather
                  MMM-Formula1
                  MMM-Growatt
                  is it an issue? Everythings seems ok except for startup (sometimes)
                    sdetweil @nowayto
                    @nowayto wow
                    Might be related to sd card speed
                    • N
                      nowayto @sdetweil
                      @sdetweil it could be. It’s a good card but it could have reached her lifespan. I’ll give it a try, thanks
