    MMM-ISS-Live error 153
    11 Posts 4 Posters 2.9k Views 4 Watching
    • R
      RonR
      Running MM V2.33.0 on Docker. I installed MMM-ISS-Live but it only shows this error message: “Error 153
      Video player configuration error”
      I have done some research and found that I need to add " referrerpolicy=“strict-origin-when-cross-origin” " to the IFrame. I looked at the MMM-ISS-Live.js file, found a section dealing with IFrame and inserted the policy statement following the format of the other Iframe statements. That change alone did not fix the problem, same error message after restarting MM.
      I noticed several references to electron and now I’m wondering if this module will even run under Docker.
      Any suggestions/thoughts greatly appreciated.
      RonR
        sdetweil @RonR
        @RonR are you using this fork
        https://github.com/KristjanESPERANTO/MMM-ISS-Live
        R 1 Reply Last reply
        • R
          RonR @sdetweil
          @sdetweil Yes, that is where I downloaded from.
            sdetweil @RonR
            @RonR did you do this step in the README
            https://github.com/KristjanESPERANTO/MMM-ISS-Live?tab=readme-ov-file#preparing-electron
            Preparing Electron
            MagicMirror² disables the <webview> tag by default. Enable it by adding the following snippet to your config/config.js:
            let config = {
              electronOptions: {
                webPreferences: {
                  webviewTag: true;
            Reply Quote 1
            • R
              RonR @sdetweil
              @sdetweil Yes, I did add that to config.js. It is nice to have done something right for a change. :)
                sdetweil @RonR
                @RonR except you have an error…
                • TAGinsideT
                  TAGinside
                  Docker often limits Electron’s graphical capabilities and full management, including restrictions related to video autoplay. Error 153 is often caused by these restrictions.
                  I’ll try to find something on my end tomorrow.
                  karsten13K R 2 Replies Last reply
                  • karsten13K
                    karsten13 @TAGinside
                    this is unrelated to mm, the default url used in the module is https://www.youtube.com/embed/yf5cEJULZXk?si=Dx852YRN5q6NHj0K and I see the same error 153 in my browser.
                    Clicking on “Watch video on YouTube” will move you to https://www.youtube.com/watch?v=yf5cEJULZXk with the content “This live stream recording is not available.”
                    So this NASA stream is at least currently not available …
                    Maybe of interest for @KristjanESPERANTO
                    TAGinsideT 1 Reply Last reply
                    Reply Quote 1
                    • TAGinsideT
                      TAGinside @karsten13
                      @karsten13
                      So if you right maybe we can use this flux on page https://www.sen.com/live
                      Or https://m.youtube.com/watch?v=iYmvCUonukw
                      • R
                        RonR @TAGinside
                        @TAGinside Thanks. I’m learning more everyday and that feels good.
                        • R RonR has marked this topic as solved on
                        • R
                          RonR
                          @TAGinside said in MMM-ISS-Live error 153:
                          @karsten13
                          @karsten13 made some changes to the environment of the module on github, I reloaded the module and the error is gone. Thanks for the help, sorry it took so long to acknowledge the fix.
