    how to revert to HTTP
    6 Posts 2 Posters 636 Views 2 Watching
    • T Offline
      travishardiman
      I had enabled HTTPS in the config.js but then the mmpm.ui stopped working and started throwing all kinds of errors:
      4|mmpm.ui  | OSError: [Errno 98] Address already in use
      4|mmpm.ui  | Traceback (most recent call last):
      4|mmpm.ui  |   File "<frozen runpy>", line 198, in _run_module_as_main
      4|mmpm.ui  |   File "<frozen runpy>", line 88, in _run_code
      4|mmpm.ui  |   File "/usr/lib/python3.11/http/server.py", line 1309, in <module>
      4|mmpm.ui  |     test(
      4|mmpm.ui  |   File "/usr/lib/python3.11/http/server.py", line 1256, in test
      4|mmpm.ui  |     with ServerClass(addr, HandlerClass) as httpd:
      4|mmpm.ui  |          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      4|mmpm.ui  |   File "/usr/lib/python3.11/socketserver.py", line 456, in __init__
      4|mmpm.ui  |     self.server_bind()
      4|mmpm.ui  |   File "/usr/lib/python3.11/http/server.py", line 1303, in server_bind
      4|mmpm.ui  |     return super().server_bind()
      4|mmpm.ui  |   File "/usr/lib/python3.11/http/server.py", line 136, in server_bind
      4|mmpm.ui  |     socketserver.TCPServer.server_bind(self)
      4|mmpm.ui  |   File "/usr/lib/python3.11/socketserver.py", line 472, in server_bind
      4|mmpm.ui  |     self.socket.bind(self.server_address)
      I tried setting useHttps: false but that didn’t appear to revert anything. Is there something special that I have to do to disable HTTPS?
      These errors seem to be repeating constantly, unsure if they’re related:
      3|mmpm.repeater    | [2025-11-09 23:48:25 -0500] [20125] [ERROR] Connection in use: ('0.0.0.0', 8907)
      2|mmpm.log-server  | [2025-11-09 23:48:25 -0500] [20124] [ERROR] Connection in use: ('0.0.0.0', 6789)
      2|mmpm.log-server  | [2025-11-09 23:48:25 -0500] [20124] [ERROR] connection to ('0.0.0.0', 6789) failed: [Errno 98] Address already in use
      3|mmpm.repeater    | [2025-11-09 23:48:25 -0500] [20125] [ERROR] connection to ('0.0.0.0', 8907) failed: [Errno 98] Address already in use
        sdetweil @travishardiman
        @travishardiman address already in use means you have another instance of MagicMirror running already
        Do you use pm2 to auto launch MagicMirror at boot
        Do
        pm2 status
        • T Offline
          travishardiman @sdetweil
          @sdetweil I manually stopped the bottom three because they were logging so many errors:
          pi@smartmirror2024:~ $ pm2 status
          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
          │ 0  │ MagicMirror        │ fork     │ 3    │ online    │ 0%       │ 2.9mb    │
          │ 1  │ mmpm.api           │ fork     │ 2    │ online    │ 0%       │ 27.2mb   │
          │ 2  │ mmpm.log-server    │ fork     │ 818  │ stopped   │ 0%       │ 0b       │
          │ 3  │ mmpm.repeater      │ fork     │ 818  │ stopped   │ 0%       │ 0b       │
          │ 4  │ mmpm.ui            │ fork     │ 150  │ stopped   │ 0%       │ 0b       │
            @travishardiman the column in the status output between
            Mode and status is the restart count column
            So 800+ is a bad thing
            • T Offline
              @sdetweil after restarting the whole pi, all the processes in pm2 seem to be running ok, and I can connect over http again.
              However there’s still some weird stuff in the logs: 😆
              3|mmpm.repeater  | [+] Connection to namespace /MMM-mmpm was rejected
              3|mmpm.repeater  | [+] Connection failed, new attempt in 4.80 seconds
              3|mmpm.repeater  | [+] Connection failed, new attempt in 4.55 seconds
              3|mmpm.repeater  | [+] Engine.IO connection dropped
              3|mmpm.repeater  | [+] Engine.IO connection established
              3|mmpm.repeater  | [+] Connection failed, new attempt in 5.47 seconds
              Are these anything that I should worry about?
                @travishardiman sorry I do not know
