    Default Calendar module frequently refreshes
    25 Posts 3 Posters 1.7k Views 3 Watching
      sdetweil @michaelarnauts
      @michaelarnauts For the log output, we were looking for the broadcasting xxxx events messages entries
      But note they have the full URL string , which you shouldn’t post on the forum
        DarrenO 0 @sdetweil
        @sdetweil said in Default Calendar module frequently refreshes:
        @DarrenO-0 sorry, not quite sure what you’ve said here
        You specified tableClass twice in the config of a single calendar module declaration?
        JavaScript should take the second, and ignore the first
        JSON.parse() should overlay the first w the second
        And tableClass is only used in the presentation of the events long after the broadcast message is sent
        Correct, yes.
        I would have assumed, and expect, that the second specified instance of “tableClass” would supersede the first, but for some reason when I removed either instance and re-saved the config, the calendar has been rock-solid and no longer performs the constant/frequent refresh outside of the fetchInterval value.
        Was the duplicate value the cause and removing it was the solution?
        Was simply re-saving the config, to force MM to re-read it, the solution?
        I don’t know, but it is all now working as expected - i see the calendar temporarily fade out and redisplay according to the configured 5min interval
        When viewing the live tail of pm2 logs --lines=15, i’m no longer seeing a constant display of the “Broadcasting…” of each calendar throughout the configured fetchInterval. I now only and correctly see it update according to the fetchInterval value.
          sdetweil @DarrenO 0
          @DarrenO-0 weird!!!
            DarrenO 0 @sdetweil
            OK, so after a few days, my MM is still on Debian12 and i’m now seeing the same constant/frequent reload of the default calendar.
            What logs should I be looking in and what should I be looking for in them?
              sdetweil @DarrenO 0
              @DarrenO-0 in the output of npm start
              There will be a line
              Broadcasting xxx events for calendar yyyy
              Where yyyy is the full url configured in the calendar
              That line will have a timestamp at the beginning of the line
              That is the output of the calendar module fetcher and starts the delivery to the front end to display
              If you use pm2 that content is captured for you
              You could use grep to extract just those lines
              cd ~/.pm2/logs
              ls
              Find the right filename.
              Pm2_app name-out.log
              grep Broadcasting fffff
              Where fffff is the file name you selected
              Note the file is added to each time MagicMirror is restarted unless you clear it first
              pm2 flush
              To clear
              Before posting in a public place, make sure to mangle the url on each line so as not to expose your working cal url
