    Default Calendar module frequently refreshes
    25 Posts 3 Posters 4.1k Views 3 Watching
      sdetweil @DarrenO 0
      @DarrenO-0 on the pm2 side there are two parts
      the code on the disk
      and the part running
      to change the part running
      you need to execute
      sudo pm2 updatePM2
        sdetweil @DarrenO 0
        @DarrenO-0 I rejected your post w the log entries, see the notification message I sent
        D 2 Replies Last reply
          DarrenO 0 @sdetweil
          @sdetweil said in Default Calendar module frequently refreshes:
          The calendar entries for the logs were unique.
          I removed the true component of the email address prior to the “@” and replaced them with calendaruser1… calendaruser4
          Incidentally, i’ve been back through the config.js file for the default calendar and found that I had specified tableClass= twice.
          The fIrst instance had a value of “small” with the bulk of the other options.
          The second instance had a value of “xsmall” and was between the customEvents[] and calendars[] arrays.
          I removed the second instance and changed the value of the first to “xsmall”.
          Saving the config automatically restarted MM and it appears to have resolved the matter as it hasn’t repeated the issue in the last hour, but i’ll continue to monitor over the next couple of days.
          Not sure how that one line could have caused the issue… Any ideas???
            DarrenO 0 @sdetweil
            one thing i’ve now noticed since removing the duplicate tableClass entry in the calendar module’s config, when i now run :
            pm2 logs --lines=15
            i am now seeing the Broadcasting ### events entries calendars update on the scheduled intervals.
            Prior, while i was having the issue, i would see a constant updating of the live view of pm2 logs.
              michaelarnauts @sdetweil
              That makes sense, but I see a lot more updates then what you describe here.
              I’ve added a screenshot of the updates I get to my github issue, and I’ve added it here as well. (note that all the messages have the same length, and some are a few seconds apart.
              I’m not sure how to proceed in troubleshooting. When I enable debug logging, it is outputting a LOT (the whole ics file contains data from years ago).
                sdetweil @DarrenO 0
                @DarrenO-0 sorry, not quite sure what you’ve said here
                You specified tableClass twice in the config of a single calendar module declaration?
                JavaScript should take the second, and ignore the first
                JSON.parse() should overlay the first w the second
                And tableClass is only used in the presentation of the events long after the broadcast message is sent
                D 1 Reply Last reply
                  sdetweil @michaelarnauts
                  @michaelarnauts For the log output, we were looking for the broadcasting xxxx events messages entries
                  But note they have the full URL string , which you shouldn’t post on the forum
                    DarrenO 0 @sdetweil
                    Correct, yes.
                    I would have assumed, and expect, that the second specified instance of “tableClass” would supersede the first, but for some reason when I removed either instance and re-saved the config, the calendar has been rock-solid and no longer performs the constant/frequent refresh outside of the fetchInterval value.
                    Was the duplicate value the cause and removing it was the solution?
                    Was simply re-saving the config, to force MM to re-read it, the solution?
                    I don’t know, but it is all now working as expected - i see the calendar temporarily fade out and redisplay according to the configured 5min interval
                    When viewing the live tail of pm2 logs --lines=15, i’m no longer seeing a constant display of the “Broadcasting…” of each calendar throughout the configured fetchInterval. I now only and correctly see it update according to the fetchInterval value.
                      sdetweil @DarrenO 0
                      @DarrenO-0 weird!!!
                        DarrenO 0 @sdetweil
                        OK, so after a few days, my MM is still on Debian12 and i’m now seeing the same constant/frequent reload of the default calendar.
                        What logs should I be looking in and what should I be looking for in them?
                          sdetweil @DarrenO 0
                          @DarrenO-0 in the output of npm start
                          There will be a line
                          Broadcasting xxx events for calendar yyyy
                          Where yyyy is the full url configured in the calendar
                          That line will have a timestamp at the beginning of the line
                          That is the output of the calendar module fetcher and starts the delivery to the front end to display
                          If you use pm2 that content is captured for you
                          You could use grep to extract just those lines
                          cd ~/.pm2/logs
                          ls
                          Find the right filename.
                          Pm2_app name-out.log
                          grep Broadcasting fffff
                          Where fffff is the file name you selected
                          Note the file is added to each time MagicMirror is restarted unless you clear it first
                          pm2 flush
                          To clear
                          Before posting in a public place, make sure to mangle the url on each line so as not to expose your working cal url
