    Default Calendar module frequently refreshes
    25 Posts 3 Posters 4.1k Views 3 Watching
      sdetweil @DarrenO 0
      @DarrenO-0 those calendar modules fetch the days themselves in their own way
        DarrenO 0 @sdetweil
        i forgot to mention that i experience the same constant refresh/reload issue on both the host and browser instances of the MM that displays the default calendar module, so i guess it’s not isolated to browser on my PC where I view both MM instances.
        What would the command be that I need to run to view the npm output?
          sdetweil @DarrenO 0
          @DarrenO-0 as MagicMirror is started by pm2 the command would be
          pm2 logs —lines=xxxx
          Two dashes in front of lines
          Where xxxx is the number of most recent lines of output, default 15
          You can also examine the files the logs are collected in,
          In the ~/.pm2/logs. Folder, notice the . in front of pm2
          The fact that you see it on other browsers confirms to
          Me that this is fetch timing cycle related.
          If you look at both displays at once, my guess is the refresh at the same time
          D 1 Reply Last reply
            DarrenO 0 @sdetweil
            I restored my MM from an image i took of it from prior to upgrading to Debian 13 and, so far, I am not experiencing the same refresh.
            I’ll keep an eye on things over the next few hours and see if the issue re-occurs.
              sdetweil @DarrenO 0
              @DarrenO-0 thx. Id really like to see the logs from both for the event broadcast cycle
              There was a big calendar parser change in. 33 and another coming in. 34
                michaelarnauts
                I just made this github issue to track this issue.
                https://github.com/MagicMirrorOrg/MagicMirror/issues/3971
                  sdetweil @michaelarnauts
                  @michaelarnauts I replied to it, but there you have a different complaint.
                  The system design is
                  Pull the iCal file via the URL
                  It’s whatever events the source calendar wants to send , we have no control , it’s all text
                  We convert that to a usable list
                  And then figure out the repeating events and get a list that could be displayed, expired and not , as of right this second
                  Then we send that list out to other modules to use
                  MMM-CalendarExt3 for example, which displays a wall cal view, using the events in view expired or not
                  Then we process the not expired list and display the xx that you wanted
                  And repeat that whole process for the next fetchInterval
                  Once every xx minutes or whatever you have it set to
                  For each URL configured , we do the exact same process, each sending events when they are fetched. One URL processor doesn’t know about the next, they ALL run independently
                  M 1 Reply Last reply
                    DarrenO 0 @sdetweil
                    @sdetweil said in Default Calendar module frequently refreshes:
                    I’d upgraded to .33 in mid-Oct and had only upgraded Debian from 12 to 13 earlier this month but don’t recall noticing the issue prior to the OS upgrade.
                    i’ll see how i go with it under Debian 12 over the weekend and probably re-upgrade to Debian 13 early next week to then see if the issue re-presents itself.
                    Interestingly, the calendar that contains the most events is the one that was listed in the pm2 logs when the host was issue under Debian 13.
                    Now that the system is back under Debian 12, I’ll recheck the logs to see if the same notification in the pm2 logs is listed.
                    One item i also noted in the pm2 logs was it identified that pm2 was out of date and i need to upgrade.
                    I’m not 100% sure, but I think my MM is currently on 6.0.6, and 6.0.13 is the latest stable version available.
                    I did attempt to upgrade pm2 from the instructions at pm2.io using “npm install pm2@latest -g” or “sudo npm install pm2@latest -g” and though it appeared to upgrade, it always returned an error that “-g” was an unknown command or option.
                    When i then run pm2 --version, it still reported that i was running 6.0.6.
                    S 2 Replies Last reply
                      sdetweil @DarrenO 0
                      @DarrenO-0 on the pm2 side there are two parts
                      the code on the disk
                      and the part running
                      to change the part running
                      you need to execute
                      sudo pm2 updatePM2
                        sdetweil @DarrenO 0
                        @DarrenO-0 I rejected your post w the log entries, see the notification message I sent
                        D 2 Replies Last reply
                          DarrenO 0 @sdetweil
                          The calendar entries for the logs were unique.
                          I removed the true component of the email address prior to the “@” and replaced them with calendaruser1… calendaruser4
                          Incidentally, i’ve been back through the config.js file for the default calendar and found that I had specified tableClass= twice.
                          The fIrst instance had a value of “small” with the bulk of the other options.
                          The second instance had a value of “xsmall” and was between the customEvents[] and calendars[] arrays.
                          I removed the second instance and changed the value of the first to “xsmall”.
                          Saving the config automatically restarted MM and it appears to have resolved the matter as it hasn’t repeated the issue in the last hour, but i’ll continue to monitor over the next couple of days.
                          Not sure how that one line could have caused the issue… Any ideas???
                            DarrenO 0 @sdetweil
                            one thing i’ve now noticed since removing the duplicate tableClass entry in the calendar module’s config, when i now run :
                            pm2 logs --lines=15
                            i am now seeing the Broadcasting ### events entries calendars update on the scheduled intervals.
                            Prior, while i was having the issue, i would see a constant updating of the live view of pm2 logs.
                              michaelarnauts @sdetweil
                              That makes sense, but I see a lot more updates then what you describe here.
                              I’ve added a screenshot of the updates I get to my github issue, and I’ve added it here as well. (note that all the messages have the same length, and some are a few seconds apart.
                              I’m not sure how to proceed in troubleshooting. When I enable debug logging, it is outputting a LOT (the whole ics file contains data from years ago).
                                sdetweil @DarrenO 0
                                @DarrenO-0 sorry, not quite sure what you’ve said here
                                You specified tableClass twice in the config of a single calendar module declaration?
                                JavaScript should take the second, and ignore the first
                                JSON.parse() should overlay the first w the second
                                And tableClass is only used in the presentation of the events long after the broadcast message is sent
                                  @michaelarnauts For the log output, we were looking for the broadcasting xxxx events messages entries
                                  But note they have the full URL string , which you shouldn’t post on the forum
                                    DarrenO 0 @sdetweil
                                    Correct, yes.
                                    I would have assumed, and expect, that the second specified instance of “tableClass” would supersede the first, but for some reason when I removed either instance and re-saved the config, the calendar has been rock-solid and no longer performs the constant/frequent refresh outside of the fetchInterval value.
                                    Was the duplicate value the cause and removing it was the solution?
                                    Was simply re-saving the config, to force MM to re-read it, the solution?
                                    I don’t know, but it is all now working as expected - i see the calendar temporarily fade out and redisplay according to the configured 5min interval
                                    When viewing the live tail of pm2 logs --lines=15, i’m no longer seeing a constant display of the “Broadcasting…” of each calendar throughout the configured fetchInterval. I now only and correctly see it update according to the fetchInterval value.
                                      sdetweil @DarrenO 0
                                      @DarrenO-0 weird!!!
                                        DarrenO 0 @sdetweil
                                        OK, so after a few days, my MM is still on Debian12 and i’m now seeing the same constant/frequent reload of the default calendar.
                                        What logs should I be looking in and what should I be looking for in them?
                                          sdetweil @DarrenO 0
                                          @DarrenO-0 in the output of npm start
                                          There will be a line
                                          Broadcasting xxx events for calendar yyyy
                                          Where yyyy is the full url configured in the calendar
                                          That line will have a timestamp at the beginning of the line
                                          That is the output of the calendar module fetcher and starts the delivery to the front end to display
                                          If you use pm2 that content is captured for you
                                          You could use grep to extract just those lines
                                          cd ~/.pm2/logs
                                          ls
                                          Find the right filename.
                                          Pm2_app name-out.log
                                          grep Broadcasting fffff
                                          Where fffff is the file name you selected
                                          Note the file is added to each time MagicMirror is restarted unless you clear it first
                                          pm2 flush
                                          To clear
                                          Before posting in a public place, make sure to mangle the url on each line so as not to expose your working cal url
