    This command "node --run install-mm" causes error "-bash: node: command not found"
    6 Posts 2 Posters 729 Views 2 Watching
    • C Offline
      CaptainKen
      After installing this https://www.raspberrypi.com/software/
      I first ran both these commands:
      sudo apt full-upgrade
      sudo apt update
      Then followed documentation on this page https://docs.magicmirror.builders/getting-started/installation.html
      This command “node --run install-mm” causes error “-bash: node: command not found” on RPi 5.
      S C 2 Replies Last reply Reply Quote 0
        sdetweil @CaptainKen
        @CaptainKen after you did the updates, did you reboot? or close and open the terminal window??
        if you updated the OS, then its best to reboot before doing anything else
        and they should have been in the opposite order…
        update the changes list
        then install the updates
        • C Offline
          CaptainKen @CaptainKen
          I did reboot after the updates.
          I just ran these commands:
          curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash -
          sudo apt install -y nodejs
          node -1 (v20.19.6)
          npm -v (10.8.2)
          Now this command “node --run install-mm” gives the error “node: bad option: --run”
            @CaptainKen yes, you need node 22 for that
            MagicMirror requires 22.18.0 for v2.33
            Next release is 22.21.1
            Node 24 removes 32 bit support. So we are trying to hold on to 32bit support as long as we can.
            • C Offline
              CaptainKen @sdetweil
              @sdetweil Thank you for replying with some details. So you’re saying I should not have installed RPi 64-bit.
                @CaptainKen no. You need to install node 22.18.0
                You installed node 20
