    Failed to Connect to Wayland Display
    58 Posts 7 Posters 6.8k Views 6 Watching
      sdetweil @atwist
      @atwist
      So it shouldn’t be trying to start using wayland
      And npm start on 2.34.0 uses x11
        atwist
        weird. Any suggestionon what to do?
          sdetweil @atwist
          @atwist move the script to another name
          Try this instead
          #!/bin/bash
          npm start
          Save that as mm.sh then do
          chmod +x mm.sh
          Then try
          pm2 start MagicMirror
            atwist @sdetweil
            @sdetweil thanks. It shows that the process started successfully but it doesn’t appear on the screen.
              sdetweil @atwist
              @atwist you are on the pi directly, right? Not via ssh or vnc
                sdetweil @atwist
                @atwist try adding these two lines in front of the
                export DISPLAY=:0
                export ELECTRON_OZONE_PLATFORM_HINT=x11
                npm start line
                And try the
                ./MagicMirror.sh again.
                May need to reboot before retry
                  atwist @sdetweil
                  @sdetweil yes directly on it
                    atwist @sdetweil
                    @sdetweil the file you are referring to is in the installers folder. Correct?
                    It does start the interface with your suggestions. Is it able to start it in reboot since it no longer does?
                      sdetweil @atwist
                      @atwist
                      pm2 status
                      Then
                      pm2 start xxx
                      Where xxx is the name or number of the row in the status output
                      Then pm2 save
                      And the sudo reboot
                        atwist @sdetweil
                        @sdetweil Unfortunately, it still doesn’t start after reboot. It does continue to work if i start it manually.
                        Log file
                        |MagicMir | [2991:0228/201716.146315:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:282] Failed to initialize Wayland platform
                        0|MagicMir | [2991:0228/201716.146344:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
                        0|MagicMir | /home/twist/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                        0|MagicMir | [3075:0228/201721.692197:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                        S H 2 Replies Last reply Reply Quote 0
                          sdetweil @atwist
                          @atwist do this
                          pm2 status
                          pm2 info xxxx
                          where xxxx is the name/number on the row that contains the MagicMirror app
                          see the line in the output (example from my Mac, )
                           script path       │ /Users/sam/MagicMirror/installers/mm.sh
                          is it pointing to the correct sh file??
                          • H Offline
                            hrt13 @atwist
                            @atwist
                            I know this may be a bit late, I had the same problem on my Raspberry Pi3 after I updated to the latest MM.
                            I spent some time trying to get Wayland running, but wasn’t really successful. Finally, I changed my mm.sh script to:
                            #!/bin/bash
                            cd ~/MagicMirror
                            npm run start:x11
                            And that got it working again using: pm2 start|restart mm
                            S V 2 Replies Last reply Reply Quote 1
                              sdetweil @hrt13
                              @hrt13 yes, the release notes indicate that the npm start defaults to Wayland now…
                              • V Offline
                                VinGroot @hrt13
                                @hrt13
                                @hrt13 said:
                                @atwist
                                #!/bin/bash
                                cd ~/MagicMirror
                                npm run start:x11
                                I got something similar, my version of mm.sh:
                                #!/bin/bash
                                cd /home/pi/MagicMirror
                                DISPLAY=:0 node --run start:x11
                                • H Offline
                                  hrt13 @sdetweil
                                  @sdetweil I modified your script from earlier to:
                                  #!/bin/bash
                                  cd ~/MagicMirror
                                  if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                     # if WAYLAND_DISPLAYis set, use it, else set to -0
                                     export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                     npm run start:wayland
                                  else
                                     npm run start:x11
                                  fi
                                    sdetweil @hrt13
                                    @hrt13 yes, I fixed it the same way for new installs
                                    Need some time to fix for existing
                                    I have fixed upgrade to update mm.sh for start:x11 if wayland is not running
                                      Scruffy @sdetweil
                                      I’m having a similar issue and I’ve been following this post but I still can’t resolve the error.
                                      [94483:0406/164800.222694:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                      [94483:0406/164800.222815:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                      [94483:0406/164800.222849:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                      /home/ferguson/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                      [94821:0406/164812.960910:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                      [94821:0406/164812.962540:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                      [94821:0406/164812.962598:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                      I’m currently using the following lines in mm.sh
                                      #!/bin/bash
                                      cd ~/MagicMirror
                                      else
                                         npm run start:x11
                                      fi
                                      Running the PM2 shows the status is online.
                                      Any help would be greatly appreciated.
                                      Cheers!
                                        sdetweil @Scruffy
                                        @Scruffy
                                        Can you open a terminal window and run this command string
                                        Then do
                                        pm2 stop all
                                        cd MagicMirror
                                        npm run start:x11
                                        Does MagicMirror start now?
                                          Scruffy @sdetweil
                                          I ran the first command and this is the output:
                                          ~ $ ps -ef | grep -v grep | grep -i -e xway -e labwc
                                          ferguson   66504       1  0 15:32 ?        00:00:01 /usr/bin/Xwayland -auth /home/ferguson/.Xauthority :0 -rootless -core -terminate 10 -listenfd 28 -listenfd 29 -displayfd 88 -wm 82
                                          When I run the last commands, it’s still not launching. The MM screen flickers up for a second and then goes away. This isn’t unique to the above steps.
                                          Logs look similar, if not the same:
                                          [306765:0406/201018.874374:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                          [306765:0406/201018.874626:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                          [306765:0406/201018.874711:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                          [307094:0406/201032.033709:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                          [307094:0406/201032.033832:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                          [307094:0406/201032.033866:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                          Strange indeed.
                                            sdetweil @Scruffy
                                            @Scruffy ok, try
                                            • 2 / 3
