    Failed to Connect to Wayland Display
    58 Posts 7 Posters 15.8k Views 6 Watching
    • A
      atwist @sdetweil
      @sdetweil Unfortunately, it still doesn’t start after reboot. It does continue to work if i start it manually.
      Log file
      |MagicMir | [2991:0228/201716.146315:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:282] Failed to initialize Wayland platform
      0|MagicMir | [2991:0228/201716.146344:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
      0|MagicMir | /home/twist/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      0|MagicMir | [3075:0228/201721.692197:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
      S H 2 Replies Last reply
        sdetweil @atwist
        @atwist do this
        pm2 status
        pm2 info xxxx
        where xxxx is the name/number on the row that contains the MagicMirror app
        see the line in the output (example from my Mac, )
         script path       │ /Users/sam/MagicMirror/installers/mm.sh
        is it pointing to the correct sh file??
        • H
          hrt13 @atwist
          @atwist
          I know this may be a bit late, I had the same problem on my Raspberry Pi3 after I updated to the latest MM.
          I spent some time trying to get Wayland running, but wasn’t really successful. Finally, I changed my mm.sh script to:
          #!/bin/bash
          npm run start:x11
          And that got it working again using: pm2 start|restart mm
          S V 2 Replies Last reply
          Reply Quote 2
            sdetweil @hrt13
            @hrt13 yes, the release notes indicate that the npm start defaults to Wayland now…
            H 1 Reply Last reply
            • V
              VinGroot @hrt13
              @hrt13
              @hrt13 said:
              @atwist
              #!/bin/bash
              npm run start:x11
              I got something similar, my version of mm.sh:
              #!/bin/bash
              cd /home/pi/MagicMirror
              DISPLAY=:0 node --run start:x11
              • H
                hrt13 @sdetweil
                @sdetweil I modified your script from earlier to:
                #!/bin/bash
                if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                   # if WAYLAND_DISPLAYis set, use it, else set to -0
                   export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                   npm run start:wayland
                else
                   npm run start:x11
                fi
                  sdetweil @hrt13
                  @hrt13 yes, I fixed it the same way for new installs
                  Need some time to fix for existing
                  I have fixed upgrade to update mm.sh for start:x11 if wayland is not running
                    Scruffy @sdetweil
                    I’m having a similar issue and I’ve been following this post but I still can’t resolve the error.
                    [94483:0406/164800.222694:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                    [94483:0406/164800.222815:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                    [94483:0406/164800.222849:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                    /home/ferguson/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                    [94821:0406/164812.960910:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                    [94821:0406/164812.962540:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                    [94821:0406/164812.962598:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                    I’m currently using the following lines in mm.sh
                    #!/bin/bash
                    else
                       npm run start:x11
                    fi
                    Running the PM2 shows the status is online.
                    Any help would be greatly appreciated.
                    Cheers!
                      sdetweil @Scruffy
                      @Scruffy
                      Can you open a terminal window and run this command string
                      Then do
                      pm2 stop all
                      cd MagicMirror
                      npm run start:x11
                      Does MagicMirror start now?
                        Scruffy @sdetweil
                        I ran the first command and this is the output:
                        ~ $ ps -ef | grep -v grep | grep -i -e xway -e labwc
                        ferguson   66504       1  0 15:32 ?        00:00:01 /usr/bin/Xwayland -auth /home/ferguson/.Xauthority :0 -rootless -core -terminate 10 -listenfd 28 -listenfd 29 -displayfd 88 -wm 82
                        When I run the last commands, it’s still not launching. The MM screen flickers up for a second and then goes away. This isn’t unique to the above steps.
                        Logs look similar, if not the same:
                        [306765:0406/201018.874374:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                        [306765:0406/201018.874626:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                        [306765:0406/201018.874711:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                        [307094:0406/201032.033709:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                        [307094:0406/201032.033832:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                        [307094:0406/201032.033866:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                        Strange indeed.
                          sdetweil @Scruffy
                          @Scruffy ok, try
                            Scruffy @sdetweil
                            Unfortunately, still no go.
                            The whole system is feeling sluggish… I wounder if it’s an SD issue…?
                            I have a new SD card arriving later today. I’ll image and reinstall MM and report back.
                            If it’s still not working, I’ll provide the logs again.
                            Cannot thank you enough, @sdetweil. You’re incredibly responsive and your support is greatly appreciated.
                            Cheers!
                            S A 2 Replies Last reply
                              sdetweil @Scruffy
                              @Scruffy use my backup/restore scripts to save and restore your MagicMirror config and modules list
                              https://github.com/sdetweil/MagicMirror-backup-restore
                              Backup, copy off backup folder, tiny size
                              Install new MagicMirror and copy back folder and restore
                              • A
                                atwist @Scruffy
                                @Scruffy I actually never resolved my issue either. But, my system was very sluggish as well.
                                S S 2 Replies Last reply
                                  sdetweil @atwist
                                  @atwist the latest PI OS is larger than the previous versions…
                                  leading to more swapping. This can affect performance because of the speed of the SD card.
                                  free -m
                                  will tell you how much memory and swap space you are using.
                                    Scruffy @atwist
                                    @atwist what did you end up doing? Or are you still without MM working?
                                      Scruffy @sdetweil
                                      @sdetweil I ran the command and this is my output.
                                                   total       used      free      shared     buff/cache   available
                                      Mem:         3992        2153      210       550        2126         1839
                                      Swap:        511         30        481
                                      Is the output in MB? Doesn’t seem like it’s to the point where everything is so slow to respond.
                                        sdetweil @Scruffy
                                        @Scruffy pi4, 4 gig?
                                          Scruffy @sdetweil
                                          @sdetweil Pi 5 4GB
                                            Scruffy @sdetweil
                                            @sdetweil UPDADE:
                                            I have MagicMirror back up and running using a new SD card. I’m guessing the old one died for whatever reason since the whole system was becoming extremely sluggish to the point it would take 10 seconds between input commands triggering.
                                            Glad to be back up and running!
                                            Thank you again for all your help troubleshooting and support us!
                                            Cheers!
                                            • 2 / 3
