    Failed to Connect to Wayland Display
    58 Posts 7 Posters 15.2k Views 6 Watching
      Scruffy @sdetweil
      I’m having a similar issue and I’ve been following this post but I still can’t resolve the error.
      [94483:0406/164800.222694:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
      [94483:0406/164800.222815:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
      [94483:0406/164800.222849:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
      /home/ferguson/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      [94821:0406/164812.960910:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
      [94821:0406/164812.962540:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
      [94821:0406/164812.962598:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
      I’m currently using the following lines in mm.sh
      #!/bin/bash
      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
         # if WAYLAND_DISPLAYis set, use it, else set to -0
         export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
         npm run start:wayland
      else
         npm run start:x11
      fi
      Running the PM2 shows the status is online.
      Any help would be greatly appreciated.
      Cheers!
        sdetweil @Scruffy
        @Scruffy
        Can you open a terminal window and run this command string
        Then do
        pm2 stop all
        cd MagicMirror
        npm run start:x11
        Does MagicMirror start now?
          Scruffy @sdetweil
          I ran the first command and this is the output:
          ~ $ ps -ef | grep -v grep | grep -i -e xway -e labwc
          ferguson   66504       1  0 15:32 ?        00:00:01 /usr/bin/Xwayland -auth /home/ferguson/.Xauthority :0 -rootless -core -terminate 10 -listenfd 28 -listenfd 29 -displayfd 88 -wm 82
          When I run the last commands, it’s still not launching. The MM screen flickers up for a second and then goes away. This isn’t unique to the above steps.
          Logs look similar, if not the same:
          [306765:0406/201018.874374:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
          [306765:0406/201018.874626:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
          [306765:0406/201018.874711:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
          [307094:0406/201032.033709:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
          [307094:0406/201032.033832:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
          [307094:0406/201032.033866:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
          Strange indeed.
            sdetweil @Scruffy
            @Scruffy ok, try
              Scruffy @sdetweil
              Unfortunately, still no go.
              The whole system is feeling sluggish… I wounder if it’s an SD issue…?
              I have a new SD card arriving later today. I’ll image and reinstall MM and report back.
              If it’s still not working, I’ll provide the logs again.
              Cannot thank you enough, @sdetweil. You’re incredibly responsive and your support is greatly appreciated.
              Cheers!
              S A 2 Replies Last reply
                sdetweil @Scruffy
                @Scruffy use my backup/restore scripts to save and restore your MagicMirror config and modules list
                https://github.com/sdetweil/MagicMirror-backup-restore
                Backup, copy off backup folder, tiny size
                Install new MagicMirror and copy back folder and restore
                • A
                  atwist @Scruffy
                  @Scruffy I actually never resolved my issue either. But, my system was very sluggish as well.
                  S S 2 Replies Last reply
                    sdetweil @atwist
                    @atwist the latest PI OS is larger than the previous versions…
                    leading to more swapping. This can affect performance because of the speed of the SD card.
                    free -m
                    will tell you how much memory and swap space you are using.
                      Scruffy @atwist
                      @atwist what did you end up doing? Or are you still without MM working?
                        Scruffy @sdetweil
                        @sdetweil I ran the command and this is my output.
                                     total       used      free      shared     buff/cache   available
                        Mem:         3992        2153      210       550        2126         1839
                        Swap:        511         30        481
                        Is the output in MB? Doesn’t seem like it’s to the point where everything is so slow to respond.
                          sdetweil @Scruffy
                          @Scruffy pi4, 4 gig?
                            Scruffy @sdetweil
                            @sdetweil Pi 5 4GB
                              Scruffy @sdetweil
                              @sdetweil UPDADE:
                              I have MagicMirror back up and running using a new SD card. I’m guessing the old one died for whatever reason since the whole system was becoming extremely sluggish to the point it would take 10 seconds between input commands triggering.
                              Glad to be back up and running!
                              Thank you again for all your help troubleshooting and support us!
                              Cheers!
                                sdetweil @Scruffy
                                @Scruffy awesome!!! Thanks for the feedback!
                                How did you migrate your config ?
                                Just interested in how people do things
                                  Scruffy @sdetweil
                                  @sdetweil I’m still very new to Linux/Pi so I was concerned I may have corrupted my original config file(s) with all the changes/modifications I was performing when trying to get the original system back up and running.
                                  I copied over the old config.js which has all my module settings.
                                  I installed MM from scratch along with all the modules. I then brought up both config.js files in Geany and copied and pasted over my configurations.
                                  Not the cleanest of methods but it worked lol.
                                    sdetweil @Scruffy
                                    @Scruffy thanks.
                                      sdetweil @Scruffy
                                      @Scruffy I strongly recommend using some backup/restore mechanism,
                                      please see my backup/restore scripts for one approach.
                                      they also support versioning, so you can tell one set of changes from another and can go back or forward…
                                      and move between systems. too…
                                      https://github.com/sdetweil/MagicMirror-backup-restore.git
                                      and I also support the install/upgrade scripts, mentioned in the MM doc, Alternative install section
                                      M S 2 Replies Last reply
                                        magicmikael @sdetweil
                                        @sdetweil, I am running into a similar occurrence but from your initial post I don’t have pm2 installed (as you can see below). Any advice would be appreciated. I have completely reimaged my Pi and retried the steps.
                                        I followed all of the standard manual install steps, have git and node and npm.
                                        This is what I am getting when attempting to run ‘node --run start’
                                        Starting server on port 8080 …
                                        [1877:0409/161415.143762:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                        [1877:0409/161415.143988:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                        [1877:0409/161415.144045:ERROR:ui/aura/env.cc:246] The platform failed to initialize. Exiting.
                                        /home/onthewall/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                        System Information
                                        • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; virtual: false; MM: v2.35.0
                                        • OS: platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.75+rpt-rpi-v8
                                        • VERSIONS: electron: 41.1.0; used node: 24.14.1; installed node: 24.14.1; npm: 11.11.0; pm2:
                                        • ENV: XDG_SESSION_TYPE: undefined; MM_CONFIG_FILE: undefined
                                          WAYLAND_DISPLAY: wayland-1; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                                        • RAM: total: 3796.68 MB; free: 3304.59 MB; used: 492.10 MB
                                        • OTHERS: uptime: 1 minutes; timeZone: America/Los_Angeles
                                          sdetweil @magicmikael
                                          @magicmikael as we said in the readme notes on the release
                                          We changed
                                          npm start/node —run start
                                          To launch for Wayland compositor
                                          If you are still on x11
                                          You need to use
                                          npm run start:x11
                                          Or
                                          node —run start:x11
                                          M 1 Reply Last reply
                                            @sdetweil, I ran a fresh install of the OS (64-bit). I would have assumed it would be all set for Wayland. Confirmed under raspi-config its “Wayland” but strangely
                                            echo $XDG_SESSION_TYPE
                                            returns nothing.
                                            I am thinking of going the pm2 route and trying to launch using your aforementioned script but I can’t imagine it would yield another result.
                                            • 3 / 3
