    Failed to Connect to Wayland Display
    58 Posts 7 Posters 7.4k Views 6 Watching
    • H Offline
      hrt13 @atwist
      @atwist
      I know this may be a bit late, I had the same problem on my Raspberry Pi3 after I updated to the latest MM.
      I spent some time trying to get Wayland running, but wasn’t really successful. Finally, I changed my mm.sh script to:
      #!/bin/bash
      npm run start:x11
      And that got it working again using: pm2 start|restart mm
      S V 2 Replies Last reply Reply Quote 2
        sdetweil @hrt13
        @hrt13 yes, the release notes indicate that the npm start defaults to Wayland now…
        • V Offline
          VinGroot @hrt13
          @hrt13
          @hrt13 said:
          @atwist
          #!/bin/bash
          npm run start:x11
          I got something similar, my version of mm.sh:
          #!/bin/bash
          cd /home/pi/MagicMirror
          DISPLAY=:0 node --run start:x11
          • H Offline
            hrt13 @sdetweil
            @sdetweil I modified your script from earlier to:
            #!/bin/bash
            if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
               # if WAYLAND_DISPLAYis set, use it, else set to -0
               export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
               npm run start:wayland
            else
               npm run start:x11
            fi
              sdetweil @hrt13
              @hrt13 yes, I fixed it the same way for new installs
              Need some time to fix for existing
              I have fixed upgrade to update mm.sh for start:x11 if wayland is not running
                Scruffy @sdetweil
                I’m having a similar issue and I’ve been following this post but I still can’t resolve the error.
                [94483:0406/164800.222694:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                [94483:0406/164800.222815:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                [94483:0406/164800.222849:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                /home/ferguson/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                [94821:0406/164812.960910:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                [94821:0406/164812.962540:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                [94821:0406/164812.962598:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                I’m currently using the following lines in mm.sh
                #!/bin/bash
                else
                   npm run start:x11
                fi
                Running the PM2 shows the status is online.
                Any help would be greatly appreciated.
                Cheers!
                  sdetweil @Scruffy
                  @Scruffy
                  Can you open a terminal window and run this command string
                  Then do
                  pm2 stop all
                  cd MagicMirror
                  npm run start:x11
                  Does MagicMirror start now?
                    Scruffy @sdetweil
                    I ran the first command and this is the output:
                    ~ $ ps -ef | grep -v grep | grep -i -e xway -e labwc
                    ferguson   66504       1  0 15:32 ?        00:00:01 /usr/bin/Xwayland -auth /home/ferguson/.Xauthority :0 -rootless -core -terminate 10 -listenfd 28 -listenfd 29 -displayfd 88 -wm 82
                    When I run the last commands, it’s still not launching. The MM screen flickers up for a second and then goes away. This isn’t unique to the above steps.
                    Logs look similar, if not the same:
                    [306765:0406/201018.874374:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                    [306765:0406/201018.874626:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                    [306765:0406/201018.874711:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                    [307094:0406/201032.033709:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                    [307094:0406/201032.033832:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                    [307094:0406/201032.033866:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                    Strange indeed.
                      sdetweil @Scruffy
                      @Scruffy ok, try
                        Scruffy @sdetweil
                        Unfortunately, still no go.
                        The whole system is feeling sluggish… I wounder if it’s an SD issue…?
                        I have a new SD card arriving later today. I’ll image and reinstall MM and report back.
                        If it’s still not working, I’ll provide the logs again.
                        Cannot thank you enough, @sdetweil. You’re incredibly responsive and your support is greatly appreciated.
                        Cheers!
                        S A 2 Replies Last reply Reply Quote 0
                          sdetweil @Scruffy
                          @Scruffy use my backup/restore scripts to save and restore your MagicMirror config and modules list
                          https://github.com/sdetweil/MagicMirror-backup-restore
                          Backup, copy off backup folder, tiny size
                          Install new MagicMirror and copy back folder and restore
                            atwist @Scruffy
                            @Scruffy I actually never resolved my issue either. But, my system was very sluggish as well.
                            S S 2 Replies Last reply Reply Quote 1
                              sdetweil @atwist
                              @atwist the latest PI OS is larger than the previous versions…
                              leading to more swapping. This can affect performance because of the speed of the SD card.
                              free -m
                              will tell you how much memory and swap space you are using.
                                Scruffy @atwist
                                @atwist what did you end up doing? Or are you still without MM working?
                                  Scruffy @sdetweil
                                  @sdetweil I ran the command and this is my output.
                                               total       used      free      shared     buff/cache   available
                                  Mem:         3992        2153      210       550        2126         1839
                                  Swap:        511         30        481
                                  Is the output in MB? Doesn’t seem like it’s to the point where everything is so slow to respond.
                                    sdetweil @Scruffy
                                    @Scruffy pi4, 4 gig?
                                      Scruffy @sdetweil
                                      @sdetweil Pi 5 4GB
                                        Scruffy @sdetweil
                                        @sdetweil UPDADE:
                                        I have MagicMirror back up and running using a new SD card. I’m guessing the old one died for whatever reason since the whole system was becoming extremely sluggish to the point it would take 10 seconds between input commands triggering.
                                        Glad to be back up and running!
                                        Thank you again for all your help troubleshooting and support us!
                                        Cheers!
                                          sdetweil @Scruffy
                                          @Scruffy awesome!!! Thanks for the feedback!
                                          How did you migrate your config ?
                                          Just interested in how people do things
                                            Scruffy @sdetweil
                                            @sdetweil I’m still very new to Linux/Pi so I was concerned I may have corrupted my original config file(s) with all the changes/modifications I was performing when trying to get the original system back up and running.
                                            I copied over the old config.js which has all my module settings.
                                            I installed MM from scratch along with all the modules. I then brought up both config.js files in Geany and copied and pasted over my configurations.
                                            Not the cleanest of methods but it worked lol.
                                            • 3 / 3
