    Failed to Connect to Wayland Display
    58 Posts 7 Posters 15.2k Views 6 Watching
      sdetweil @Scruffy
      @Scruffy use my backup/restore scripts to save and restore your MagicMirror config and modules list
      https://github.com/sdetweil/MagicMirror-backup-restore
      Backup, copy off backup folder, tiny size
      Install new MagicMirror and copy back folder and restore
      • A
        atwist @Scruffy
        @Scruffy I actually never resolved my issue either. But, my system was very sluggish as well.
        S S 2 Replies Last reply
          sdetweil @atwist
          @atwist the latest PI OS is larger than the previous versions…
          leading to more swapping. This can affect performance because of the speed of the SD card.
          free -m
          will tell you how much memory and swap space you are using.
            Scruffy @atwist
            @atwist what did you end up doing? Or are you still without MM working?
              Scruffy @sdetweil
              @sdetweil I ran the command and this is my output.
                           total       used      free      shared     buff/cache   available
              Mem:         3992        2153      210       550        2126         1839
              Swap:        511         30        481
              Is the output in MB? Doesn’t seem like it’s to the point where everything is so slow to respond.
                sdetweil @Scruffy
                @Scruffy pi4, 4 gig?
                  Scruffy @sdetweil
                  @sdetweil Pi 5 4GB
                    Scruffy @sdetweil
                    @sdetweil UPDADE:
                    I have MagicMirror back up and running using a new SD card. I’m guessing the old one died for whatever reason since the whole system was becoming extremely sluggish to the point it would take 10 seconds between input commands triggering.
                    Glad to be back up and running!
                    Thank you again for all your help troubleshooting and support us!
                    Cheers!
                      sdetweil @Scruffy
                      @Scruffy awesome!!! Thanks for the feedback!
                      How did you migrate your config ?
                      Just interested in how people do things
                        Scruffy @sdetweil
                        @sdetweil I’m still very new to Linux/Pi so I was concerned I may have corrupted my original config file(s) with all the changes/modifications I was performing when trying to get the original system back up and running.
                        I copied over the old config.js which has all my module settings.
                        I installed MM from scratch along with all the modules. I then brought up both config.js files in Geany and copied and pasted over my configurations.
                        Not the cleanest of methods but it worked lol.
                          sdetweil @Scruffy
                          @Scruffy thanks.
                            sdetweil @Scruffy
                            @Scruffy I strongly recommend using some backup/restore mechanism,
                            please see my backup/restore scripts for one approach.
                            they also support versioning, so you can tell one set of changes from another and can go back or forward…
                            and move between systems. too…
                            https://github.com/sdetweil/MagicMirror-backup-restore.git
                            and I also support the install/upgrade scripts, mentioned in the MM doc, Alternative install section
                            M S 2 Replies Last reply
                              magicmikael @sdetweil
                              @sdetweil, I am running into a similar occurrence but from your initial post I don’t have pm2 installed (as you can see below). Any advice would be appreciated. I have completely reimaged my Pi and retried the steps.
                              I followed all of the standard manual install steps, have git and node and npm.
                              This is what I am getting when attempting to run ‘node --run start’
                              Starting server on port 8080 …
                              [1877:0409/161415.143762:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                              [1877:0409/161415.143988:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                              [1877:0409/161415.144045:ERROR:ui/aura/env.cc:246] The platform failed to initialize. Exiting.
                              /home/onthewall/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                              System Information
                              • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.2; virtual: false; MM: v2.35.0
                              • OS: platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.75+rpt-rpi-v8
                              • VERSIONS: electron: 41.1.0; used node: 24.14.1; installed node: 24.14.1; npm: 11.11.0; pm2:
                              • ENV: XDG_SESSION_TYPE: undefined; MM_CONFIG_FILE: undefined
                                WAYLAND_DISPLAY: wayland-1; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                              • RAM: total: 3796.68 MB; free: 3304.59 MB; used: 492.10 MB
                              • OTHERS: uptime: 1 minutes; timeZone: America/Los_Angeles
                                sdetweil @magicmikael
                                @magicmikael as we said in the readme notes on the release
                                We changed
                                npm start/node —run start
                                To launch for Wayland compositor
                                If you are still on x11
                                You need to use
                                npm run start:x11
                                Or
                                node —run start:x11
                                M 1 Reply Last reply
                                  @sdetweil, I ran a fresh install of the OS (64-bit). I would have assumed it would be all set for Wayland. Confirmed under raspi-config its “Wayland” but strangely
                                  echo $XDG_SESSION_TYPE
                                  returns nothing.
                                  I am thinking of going the pm2 route and trying to launch using your aforementioned script but I can’t imagine it would yield another result.
                                    @magicmikael if you do env
                                    Do you see wayland_display in the list?
                                    The script sets WAYLAND_DISPLAY if not already set
                                    Here is the script , make sure to make it executable
                                    chmod +x mm.sh
                                    #!/bin/bash
                                    if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                       # if WAYLAND_DISPLAYis set, use it, else set to -0
                                       export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                       npm run start:wayland
                                    else
                                       DISPLAY=:0 npm run start:x11
                                    fi
                                      Scruffy @sdetweil
                                      OK perfect! I’ll run through this process next time this occurs. Thanks!
                                      • 3 / 3
