    Failed to Connect to Wayland Display
    58 Posts 7 Posters 15.0k Views 6 Watching
      sdetweil @atwist
      @atwist move the script to another name
      Try this instead
      #!/bin/bash
      npm start
      Save that as mm.sh then do
      chmod +x mm.sh
      Then try
      pm2 start MagicMirror
      • A
        atwist @sdetweil
        @sdetweil thanks. It shows that the process started successfully but it doesn’t appear on the screen.
          sdetweil @atwist
          @atwist you are on the pi directly, right? Not via ssh or vnc
            sdetweil @atwist
            @atwist try adding these two lines in front of the
            export DISPLAY=:0
            export ELECTRON_OZONE_PLATFORM_HINT=x11
            npm start line
            And try the
            ./MagicMirror.sh again.
            May need to reboot before retry
            • A
              atwist @sdetweil
              @sdetweil yes directly on it
              • A
                atwist @sdetweil
                @sdetweil the file you are referring to is in the installers folder. Correct?
                It does start the interface with your suggestions. Is it able to start it in reboot since it no longer does?
                  sdetweil @atwist
                  @atwist
                  pm2 status
                  Then
                  pm2 start xxx
                  Where xxx is the name or number of the row in the status output
                  Then pm2 save
                  And the sudo reboot
                  • A
                    atwist @sdetweil
                    @sdetweil Unfortunately, it still doesn’t start after reboot. It does continue to work if i start it manually.
                    Log file
                    |MagicMir | [2991:0228/201716.146315:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:282] Failed to initialize Wayland platform
                    0|MagicMir | [2991:0228/201716.146344:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
                    0|MagicMir | /home/twist/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                    0|MagicMir | [3075:0228/201721.692197:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                    S H 2 Replies Last reply Reply Quote 0
                      sdetweil @atwist
                      @atwist do this
                      pm2 status
                      pm2 info xxxx
                      where xxxx is the name/number on the row that contains the MagicMirror app
                      see the line in the output (example from my Mac, )
                       script path       │ /Users/sam/MagicMirror/installers/mm.sh
                      is it pointing to the correct sh file??
                      • H
                        hrt13 @atwist
                        @atwist
                        I know this may be a bit late, I had the same problem on my Raspberry Pi3 after I updated to the latest MM.
                        I spent some time trying to get Wayland running, but wasn’t really successful. Finally, I changed my mm.sh script to:
                        #!/bin/bash
                        npm run start:x11
                        And that got it working again using: pm2 start|restart mm
                        S V 2 Replies Last reply Reply Quote 2
                          sdetweil @hrt13
                          @hrt13 yes, the release notes indicate that the npm start defaults to Wayland now…
                          • V
                            VinGroot @hrt13
                            @hrt13
                            @hrt13 said:
                            @atwist
                            #!/bin/bash
                            npm run start:x11
                            I got something similar, my version of mm.sh:
                            #!/bin/bash
                            cd /home/pi/MagicMirror
                            DISPLAY=:0 node --run start:x11
                            • H
                              hrt13 @sdetweil
                              @sdetweil I modified your script from earlier to:
                              #!/bin/bash
                              if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                 # if WAYLAND_DISPLAYis set, use it, else set to -0
                                 export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                 npm run start:wayland
                              else
                                 npm run start:x11
                              fi
                                sdetweil @hrt13
                                @hrt13 yes, I fixed it the same way for new installs
                                Need some time to fix for existing
                                I have fixed upgrade to update mm.sh for start:x11 if wayland is not running
                                  Scruffy @sdetweil
                                  I’m having a similar issue and I’ve been following this post but I still can’t resolve the error.
                                  [94483:0406/164800.222694:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                  [94483:0406/164800.222815:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                  [94483:0406/164800.222849:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                  /home/ferguson/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                                  [94821:0406/164812.960910:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                  [94821:0406/164812.962540:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                  [94821:0406/164812.962598:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                  I’m currently using the following lines in mm.sh
                                  #!/bin/bash
                                  else
                                     npm run start:x11
                                  fi
                                  Running the PM2 shows the status is online.
                                  Any help would be greatly appreciated.
                                  Cheers!
                                    sdetweil @Scruffy
                                    @Scruffy
                                    Can you open a terminal window and run this command string
                                    Then do
                                    pm2 stop all
                                    cd MagicMirror
                                    npm run start:x11
                                    Does MagicMirror start now?
                                      Scruffy @sdetweil
                                      I ran the first command and this is the output:
                                      ~ $ ps -ef | grep -v grep | grep -i -e xway -e labwc
                                      ferguson   66504       1  0 15:32 ?        00:00:01 /usr/bin/Xwayland -auth /home/ferguson/.Xauthority :0 -rootless -core -terminate 10 -listenfd 28 -listenfd 29 -displayfd 88 -wm 82
                                      When I run the last commands, it’s still not launching. The MM screen flickers up for a second and then goes away. This isn’t unique to the above steps.
                                      Logs look similar, if not the same:
                                      [306765:0406/201018.874374:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                      [306765:0406/201018.874626:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                      [306765:0406/201018.874711:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                      [307094:0406/201032.033709:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:202] Failed to connect to Wayland display: No such file or directory (2)
                                      [307094:0406/201032.033832:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:281] Failed to initialize Wayland platform
                                      [307094:0406/201032.033866:ERROR:ui/aura/env.cc:246] The platform failed to initialize.  Exiting.
                                      Strange indeed.
                                        sdetweil @Scruffy
                                        @Scruffy ok, try
                                          Scruffy @sdetweil
                                          Unfortunately, still no go.
                                          The whole system is feeling sluggish… I wounder if it’s an SD issue…?
                                          I have a new SD card arriving later today. I’ll image and reinstall MM and report back.
                                          If it’s still not working, I’ll provide the logs again.
                                          Cannot thank you enough, @sdetweil. You’re incredibly responsive and your support is greatly appreciated.
                                          Cheers!
                                          S A 2 Replies Last reply Reply Quote 0
                                            sdetweil @Scruffy
                                            @Scruffy use my backup/restore scripts to save and restore your MagicMirror config and modules list
                                            https://github.com/sdetweil/MagicMirror-backup-restore
                                            Backup, copy off backup folder, tiny size
                                            Install new MagicMirror and copy back folder and restore
                                            • 2 / 3
