    Version 2.34.0 - Missing X Server or $DISPLAY (Docker version of MMOS)
    15 Posts 3 Posters 2.8k Views 3 Watching
      Mathes75
      G’Morning everyone reading this!
      Yesterday I set up a new MagicMirror, using a Raspberry Pi 3 B+, a 16GB SD with the most recent image from https://gitlab.com/khassel/magicmirror, connected to a HDMI monitor.
      It fired up, did some magic, I was able to install my favorite modules, but after individualizing the config.js to use those modules (MMM-WordClock, MMM-Remote-Control) and to customize my view, the MagicMirror just starts every third (hard-)reboot.
      docker logs mm output:
      [entrypoint 07:02:17.102] [INFO]  symlink default modules
      [2026-01-09 08:02:20.468] [LOG]   [app] Starting MagicMirror: v2.34.0
      [2026-01-09 08:02:20.489] [LOG]   [app] Loading config ...
      [2026-01-09 08:02:20.496] [LOG]   [app] config template file not exists, no envsubst
      [2026-01-09 08:02:21.782] [INFO]  [check_config] Checking config file /opt/magic_mirror/config/config.js ...
      [2026-01-09 08:02:22.038] [INFO]  [check_config] Your configuration file doesn't contain syntax errors :)
      [2026-01-09 08:02:22.042] [INFO]  [check_config] Checking modules structure configuration ...
      [2026-01-09 08:02:22.352] [INFO]  [check_config] Your modules structure configuration doesn't contain errors :)
      [2026-01-09 08:02:22.358] [LOG]   [app] Loading module helpers ...
      [2026-01-09 08:02:22.362] [LOG]   [app] No helper found for module: MMM-WordClock.
      [2026-01-09 08:02:22.364] [LOG]   [app] No helper found for module: alert.
      [2026-01-09 08:02:22.386] [LOG]   [node_helper] Initializing new module helper ...
      [2026-01-09 08:02:22.388] [LOG]   [node_helper] Module helper loaded: updatenotification
      [2026-01-09 08:02:22.390] [LOG]   [app] No helper found for module: clock.
      [2026-01-09 08:02:22.560] [LOG]   [node_helper] Initializing new module helper ...
      [2026-01-09 08:02:22.562] [LOG]   [node_helper] Module helper loaded: calendar
      [2026-01-09 08:02:22.563] [LOG]   [app] No helper found for module: weather.
      [2026-01-09 08:02:22.763] [LOG]   [node_helper] Initializing new module helper ...
      [2026-01-09 08:02:22.764] [LOG]   [node_helper] Module helper loaded: newsfeed
      [2026-01-09 08:02:22.957] [LOG]   [node_helper] Initializing new module helper ...
      [2026-01-09 08:02:22.958] [LOG]   [node_helper] Module helper loaded: MMM-Remote-Control
      [2026-01-09 08:02:22.960] [LOG]   [app] All module helpers loaded.
      [2026-01-09 08:02:22.980] [LOG]   [server] Starting server on port 8080 ...
      [2026-01-09 08:02:22.986] [WARN]  [server] You're using a full whitelist configuration to allow for all IPs
      [2026-01-09 08:02:23.076] [LOG]   [app] Server started ...
      [2026-01-09 08:02:23.079] [LOG]   [node_helper] Connecting socket for: updatenotification
      [2026-01-09 08:02:23.081] [LOG]   [node_helper] Starting module helper: updatenotification
      [2026-01-09 08:02:23.083] [LOG]   [node_helper] Connecting socket for: calendar
      [2026-01-09 08:02:23.085] [LOG]   [calendar] Starting node helper for: calendar
      [2026-01-09 08:02:23.087] [LOG]   [node_helper] Connecting socket for: newsfeed
      [2026-01-09 08:02:23.088] [LOG]   [newsfeed] Starting node helper for: newsfeed
      [2026-01-09 08:02:23.090] [LOG]   [node_helper] Connecting socket for: MMM-Remote-Control
      [2026-01-09 08:02:23.092] [LOG]   [MMM-Remote-Control] Starting node helper for: MMM-Remote-Control
      [2026-01-09 08:02:23.108] [LOG]   [app] Sockets connected & modules started ...
      [22:0109/070223.113337:ERROR:ui/ozone/platform/x11/ozone_platform_x11.cc:249] Missing X server or $DISPLAY
      [22:0109/070223.113675:ERROR:ui/aura/env.cc:257] The platform failed to initialize.  Exiting.
      /opt/magic_mirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      I tried to use the search, but as I am running the lite OS without X Server, I don’t know where to start.
      A successful start with everything displaying fine gives something strange in the logs:
      [2026-01-09 09:38:26.915] [LOG]   [app] Sockets connected & modules started ...
      [21:0109/083829.686193:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /run/user/1000/bus: No such file or directory
      [21:0109/083829.686503:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /run/user/1000/bus: No such file or directory
      [21:0109/083829.686874:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /run/user/1000/bus: No such file or directory
      [2026-01-09 09:38:30.770] [LOG]   [electron] Launching application.
      [21:0109/083832.536207:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
      [21:0109/083832.553143:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /run/user/1000/bus: No such file or directory
      [21:0109/083832.553419:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /run/user/1000/bus: No such file or directory
      [21:0109/083832.553587:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /run/user/1000/bus: No such file or directory
      [21:0109/083832.554321:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /run/user/1000/bus: No such file or directory
      [21:0109/083832.554443:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
      [2026-01-09 09:38:43.125] [INFO]  [utils]
      ####  System Information  ####
      - SYSTEM:   manufacturer: ; model: Docker Container; virtual: false; MM: 2.34.0
      - OS:       platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
      - VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 24.12.0; npm: 11.7.0; pm2:
      - ENV:      XDG_SESSION_TYPE: undefined; MM_CONFIG_FILE: undefined
                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: unix:0.0; ELECTRON_ENABLE_GPU: 0
      - RAM:      total: 906.04 MB; free: 443.12 MB; used: 462.92 MB
      - OTHERS:   uptime: 2 minutes; timeZone: Europe/Berlin
      • karsten13K Offline
        karsten13 @Mathes75
        @Mathes75
        looks like you still have an old labwc image, try from /opt/mm/run folder:
        docker compose pull
        docker compose up -d
          sdetweil @Mathes75
          @Mathes75 you are runnng the pios with desktop,
          correct. ?
          A browser requires the graphical desktop as all the ui is drawn in graphics mode
            @karsten13 any debug we can look at?
              karsten13 @sdetweil
              the dbus errors in the mm logs are only noise, see https://forum.magicmirror.builders/topic/20032/docker-watchtower-container-restarting-and-mm-container-errors-after-upgrade/7#
              If the problem occurs:
              • can you provide the logs of the labwc container? docker logs labwc
              • can yo try to restart the containers without reboot with cd /opt/mm/run && docker compose up -d --force-recreate?
                sdetweil @karsten13
                @karsten13 thanks
                  karsten13 @sdetweil
                  other questions (not clear from description):
                  Are you using mmos or are you using Raspberry Pi OS or another OS?
                  If not mmos, how did you the install? With the install script inside the repo?
                  Can you provide output of docker compose config?
                    Mathes75
                    Thanks a lot for having a look at my issue!
                    As mentioned in the first post, I downloaded the most recent Docker image of MagicMirrorOS. - no desktop, lite version. Wrote the image with Balena Etcher and let the Rpi do it’s magic after booting until “factory” MagicMirror was shown. SSHed into the Rpi and ran sudo raspi-config to adjust locales and WiFi.
                    I installed the desired Modules, modified the config.js - and now the Mirror works only at every third or fourth boot. (Sometimes real power cycle, sometimes sudo shutdown -r now - sometimes first works, sometimes second)
                    Currently it’sworking, only one Module has issues. Both containers recreated and restarted, output of docker logs labwc
                    00:00:00.000 [INFO] [seatd/seat.c:48] Created VT-bound seat seat0
                    00:00:00.000 [INFO] [seatd/seatd.c:194] seatd started
                    failed to connect to display
                    00:00:01.036 [INFO] [seatd/server.c:145] New client connected (pid: 1, uid: 1000, gid: 1000)
                    00:00:01.036 [INFO] [seatd/seat.c:239] Added client 1 to seat0
                    00:00:01.037 [INFO] [seatd/seat.c:563] Opened client 1 on seat0
                    HDMI-A-1 "Lenovo Group Limited T2224pD V902B58B (HDMI-A-1)"
                      Make: Lenovo Group Limited
                      Model: T2224pD
                      Serial: V902B58B
                      Physical size: 480x270 mm
                      Enabled: yes
                      Modes:
                        1920x1080 px, 60.000000 Hz (preferred, current)
                        1920x1080 px, 59.939999 Hz
                        1920x1080 px, 50.000000 Hz
                        1680x1050 px, 59.882999 Hz
                        1600x900 px, 75.000000 Hz
                        1600x900 px, 60.000000 Hz
                        1280x1024 px, 75.025002 Hz
                        1280x1024 px, 70.000999 Hz
                        1280x1024 px, 60.020000 Hz
                        1440x900 px, 59.901001 Hz
                        1366x768 px, 59.790001 Hz
                        1152x864 px, 75.000000 Hz
                        1280x720 px, 60.000000 Hz
                        1280x720 px, 59.939999 Hz
                        1280x720 px, 50.000000 Hz
                        1024x768 px, 75.028999 Hz
                        1024x768 px, 70.069000 Hz
                        1024x768 px, 60.004002 Hz
                        832x624 px, 74.551003 Hz
                        800x600 px, 75.000000 Hz
                        800x600 px, 72.188004 Hz
                        800x600 px, 60.317001 Hz
                        800x600 px, 56.250000 Hz
                        720x576 px, 50.000000 Hz
                        720x480 px, 60.000000 Hz
                        720x480 px, 59.939999 Hz
                        640x480 px, 75.000000 Hz
                        640x480 px, 72.808998 Hz
                        640x480 px, 60.000000 Hz
                        640x480 px, 59.939999 Hz
                        720x400 px, 70.082001 Hz
                      Position: 0,0
                      Transform: normal
                      Scale: 1.000000
                      Adaptive Sync: disabled
                    Output of docker compose config
                    services:
                      labwc:
                        container_name: labwc
                        environment:
                          LAB_WC_HIDE_CURSOR: "true"
                          RANDR_PARAMS: ""
                          RANDR_POLL: 1m
                          XDG_RUNTIME_DIR: /run/user/1000
                        image: karsten13/labwc:latest
                        networks:
                          default: null
                        privileged: true
                        restart: always
                        volumes:
                          - type: bind
                            source: /run/user/1000
                            target: /run/user/1000
                            bind: {}
                          - type: bind
                            source: /run/udev
                            target: /run/udev
                            bind: {}
                      magicmirror:
                        container_name: mm
                        environment:
                          DBUS_SESSION_BUS_ADDRESS: unix:path=/run/user/1000/bus
                          DBUS_SYSTEM_BUS_ADDRESS: unix:path=/run/user/1000/bus
                          DISPLAY: unix:0.0
                          ELECTRON_ENABLE_GPU: "0"
                          MM_CUSTOMCSS_FILE: css/custom.css
                          MM_MODULES_DIR: modules
                          MM_OVERRIDE_DEFAULT_MODULES: "true"
                          MM_SCENARIO: electron
                          MM_SHOW_CURSOR: "false"
                        image: karsten13/magicmirror:latest
                        network_mode: host
                        privileged: true
                        restart: always
                        shm_size: "268435456"
                        volumes:
                          - type: bind
                            source: /tmp/.X11-unix
                            target: /tmp/.X11-unix
                            bind: {}
                          - type: bind
                            source: /home/pi/.Xauthority
                            target: /home/node/.Xauthority
                            bind: {}
                          - type: bind
                            bind: {}
                          - type: bind
                            source: /opt/mm/mounts/config
                            target: /opt/magic_mirror/config
                            bind: {}
                          - type: bind
                            source: /opt/mm/mounts/modules
                            target: /opt/magic_mirror/modules
                            bind: {}
                          - type: bind
                            source: /opt/mm/mounts/css/custom.css
                            target: /opt/magic_mirror/css/custom.css
                            bind: {}
                        post_start:
                          - command:
                              - /bin/sh
                              - -c
                                [ "init" = "init" ] || exit 0
                                chown -R 1000:1000 config modules css/custom.css
                                chmod -R 777 config modules css/custom.css
                            user: root
                            environment:
                              MM_CHMOD: null
                              MM_GID: null
                              MM_INIT: null
                              MM_UID: null
                    networks:
                      default:
                    Have a nice weekend!
                      karsten13 @Mathes75
                      @Mathes75
                      not sure I really fixed it but you can try
                      cd /opt/mm
                      git pull
                      ./install/install.sh electron
                      Let me know if there are still problems after reboot or not.
                        Mathes75 @karsten13
                        Thanks @karsten13!
                        git pull needed a commit to work. Done. Installing Electron revealed no change to apply.
                        At least I seem to be one step further: Recreating the images as mentioned in a post above repeatedly resolved the "missing X Server"message each time and started MagicMirror…
                        As I am quite done with all changes and adaptions, I am fine to keep the workaround with recreating the image(s), once the mirror needs a restart.
                          karsten13 @Mathes75
                          @Mathes75
                          Let me know if you get another black screen without mm start after reboot (I want to know if it is fixed or not …)
                          Can you please show me again the output of docker compose config (so I can check if you have the latest changes)?
                            Mathes75 @karsten13
                            @karsten13 New issue. I did the
                            cd /opt/mm
                            git pull
                            again and now I’m facing:
                            pi@magicmirrorMB:/opt/mm $ ./install/install.sh electron
                            --> Check docker installation
                            Docker is already installed:
                            Docker version 29.1.3, build f52814d
                            Docker Compose version v5.0.1
                            Found no xserver or wayland so using own container
                            --> Pulling container images and starting magicmirror
                            Going to remove mm
                            [+] remove 1/1
                             ✔ Container mm Removed        0.1s
                            WARN[0000] No services to build
                            [+] up 2/2
                             ✘ Container labwc Error dependency labwc failed to start        1.3s
                             ✔ Container mm    Created        0.6s
                            dependency failed to start: container labwc has no healthcheck configured
                            Don´t know what went wrong.
                            Output of docker compose config is:
                            pi@magicmirrorMB:/opt/mm/run $ docker compose config
                            services:
                              labwc:
                                environment:
                                  RANDR_PARAMS: ""
                                  RANDR_POLL: 1m
                                  XDG_RUNTIME_DIR: /tmp/labwc
                                networks:
                                  default: null
                                privileged: true
                                restart: always
                                volumes:
                                  - type: bind
                                    source: /tmp/labwc
                                    target: /tmp/labwc
                                    bind: {}
                                  - type: bind
                                    source: /run/udev
                                    target: /run/udev
                                    bind: {}
                              magicmirror:
                                container_name: mm
                                depends_on:
                                  labwc:
                                    condition: service_healthy
                                    restart: true
                                    required: true
                                environment:
                                  DISPLAY: unix:0.0
                                network_mode: host
                                privileged: true
                                restart: always
                                volumes:
                                  - type: bind
                                    bind: {}
                                  - type: bind
                                    bind: {}
                                  - type: bind
                                    source: /tmp/labwc
                                    target: /tmp/labwc
                                    bind: {}
                                  - type: bind
                                    bind: {}
                                  - type: bind
                                    bind: {}
                                  - type: bind
                                    bind: {}
                                post_start:
                                  - command:
                                      - /bin/sh
                                      - -c
                                        if [ "init" = "init" ]; then
                                          # update volume permissions
                                        fi
                                        if command -v node_modules/.bin/electron > /dev/null; then
                                          # if electron is installed then start dbus-daemon to avoid errors in the logs
                                          dbus-daemon --system || true
                                        fi
                                    user: root
                            networks:
                              default:
                            Any way to get back to the easy issue?
                              karsten13 @Mathes75
                              @Mathes75
                              docker compose pull
                                Mathes75 @karsten13
                                @karsten13
                                Back to function! Several restarts without blank screen!
                                Output of docker compose config - in case it is useful…
                                services:
                                  labwc:
                                    environment:
                                      RANDR_PARAMS: ""
                                      RANDR_POLL: 1m
                                    networks:
                                      default: null
                                    privileged: true
                                    restart: always
                                    volumes:
                                      - type: bind
                                        source: /tmp/labwc
                                        target: /tmp/labwc
                                        bind: {}
                                      - type: bind
                                        source: /run/udev
                                        target: /run/udev
                                        bind: {}
                                  magicmirror:
                                    container_name: mm
                                    depends_on:
                                      labwc:
                                        restart: true
                                        required: true
                                    environment:
                                      DISPLAY: unix:0.0
                                    network_mode: host
                                    privileged: true
                                    restart: always
                                    volumes:
                                      - type: bind
                                        bind: {}
                                      - type: bind
                                        bind: {}
                                      - type: bind
                                        source: /tmp/labwc
                                        target: /tmp/labwc
                                        bind: {}
                                      - type: bind
                                        bind: {}
                                      - type: bind
                                        bind: {}
                                      - type: bind
                                        bind: {}
                                    post_start:
                                      - command:
                                          - /bin/sh
                                          - -c
                                            fi
                                            fi
                                        user: root
                                networks:
                                  default:
                                  Mathes75 @Mathes75
                                  Pi rebooted twice today (initiated by myself) and issue didn’t come back - I think this can bei marked as resolved - thanks a lot!
                                  Now I can take care about Python and fritzconnector…
                                    sdetweil @Mathes75
                                    @Mathes75 can you find the message that best explains the fix,
                                    click the 3 dots to the right and select
                                    Mark this post as the correct answer
                                    • M Mathes75 has marked this topic as solved on
