    openweatermaps
    2 Posts 2 Posters 653 Views 2 Watching
    • V Offline
      videogame95
      Re: [Just upgrade MM and weather app with openweathermap is busted.](/topic/19961/just-upgrade-mm-and-weather-app-with-openweathermap-is-busted.Hi how do add the update node I using 3rd paty weather modules
      i add my credit card to api openweathermaps do you need to still download city clients list to get longitude and latitude or can i just get of google ?
        sdetweil @videogame95
        @videogame95 from the doc
        https://docs.magicmirror.builders/modules/weather.html#openweathermap-options
        in v3, location and locationID are not used. only lat/lon
        also
        https://forum.magicmirror.builders/topic/19323/version-2.30.0-weather-module-stuck-loading-worked-fine-before-upgrade?page=1
        also, in old api we got the location back and added it to the header
        in 3.0 api we don’t so YOU have to set the header for the module
        AND
        set
        appendLocationNameToHeader:false
        in the weather module config
