    MMM-Kermis
    1 Posts 1 Posters 298 Views 1 Watching
    • htilburgsH
      htilburgs
      MMM-Kermis
      This a module for Magic Mirror².
      This displays the Carnivals (Kermis), you can add, update and delete through a webinterface.
      This module is only available in Dutch.
      image image
      Installation
      Clone this repository in your modules folder, and install dependencies:
      cd ~/MagicMirror/modules
      git clone https://github.com/htilburgs/MMM-Kermis.git
      cd MMM-Kermis
      npm install
      Update
      When you need to update this module:
      cd ~/MagicMirror/modules/MMM-Kermis
      git pull
      npm install
      Configuration
      Go to the MagicMirror/config directory and edit the config.js file.
      Add the module to your modules array in your config.js.
        module: "MMM-Kermis",
        header: "Mijn Kermissen",
        disabled: false,
                refreshInterval: 60 * 1000 // 1 minuut
      Load Webinterface for updating the Carnivals (Kermissen)
      Open a browser and type http://serverip address:3001
      So if for example you’re MagicMirror is on 192.168.0.48 then you go to http://192.168.0.48:3001
      The Webinterface for MMM-Kermis will be loaded and you will be able to:
      image add Kermis
      image complete Kermis
      image delete Kermis
      image edit Kermis
      image sort Kermis information
      All the updates are instantly published on your Mirror
      Versions
      v1.0.0 - Initial release
      v1.1.0 - Update for Chromium, install fonts-noto-color-emoji
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
