    Calendar views load as hidden
    6 Posts 2 Posters 686 Views 2 Watching
    • M
      mmmmh Project Sponsor
      I don’t know where I took a wrong turn but my calendar views (MMM-CalendarExt2) load with the hidden class.
      I disabled all other modules. I trimmed everything down to defaults, cleaned out custom.css. I do not know where it came from. I previously used the Remote Control and Scenes2 module but I removed their configs from config.js.
      What is happening? How can I fix this?
      • M
        mmmmh Project Sponsor @mmmmh
        I think I found the issue, the scenes section for MMM-CalendarExt2 had an error. I discovered it by explicitly looking at errors in the console (and ignoring the many warnings).
        Reply Quote 2
          sdetweil @mmmmh
          @mmmmh you should be using Ext3. It gets its events from the default calendar module
          I would guess on ext2 it is waiting for its event loader to provide some events
          M 1 Reply Last reply
          • M
            mmmmh Project Sponsor @sdetweil
            @sdetweil Thanks for your comments. My CSS tweaks (which I disabled for my troubleshooting) are geared towards Ext2 (which has become active again) but I will look into Ext3.
            There is no fetching delay. The modules are literally hidden. I can inspect, remove the class and see the data.
              sdetweil @mmmmh
              @mmmmh are you using mmm-pages or something like that?
              • M
                @sdetweil In my non-troubleshooting setup I use Scenes2 and remote-API. In my troubleshooting setup I only use Calendar-Ext2. I just updated it and see if it makes a difference.
                • M
                  Reply Quote 2
                  • M mmmmh has marked this topic as solved on
