    obsession with modul checker
    19 Posts 4 Posters 230 Views 4 Watching
    • H Offline
      HeikoGr @htilburgs
      @htilburgs my main objection was to support the module development. so yes, at the moment it’s a per module check,
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH Offline
        htilburgs @HeikoGr
        @HeikoGr
        Oké, clear. Thanks for the quick replys
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        • KristjanESPERANTOK Offline
          KristjanESPERANTO Module Developer @htilburgs
          @heikogr Nice idea! I’ll take a closer look.
          • H Offline
            HeikoGr
            @htilburgs now it should work for all installed modules
              htilburgs @HeikoGr
              @HeikoGr
              So now I put It in the MagicMirror folder?
              • H Offline
                HeikoGr @htilburgs
                @htilburgs the script looks if it is under an magicmirror/modules folder and takes this as root folder for modules.
                otherwise it will take /opt/magic_mirror/modules
                if your setup is different you need to adapt the script.
                the script itself can be placed independently
                htilburgsH S 2 Replies Last reply Reply Quote 0
                  htilburgs @HeikoGr
                  @HeikoGr
                  Oké, thank you
                    sdetweil @HeikoGr
                    @HeikoGr the script could check and provide a parameter
                      htilburgs @htilburgs
                      @heikogr
                      I gave it a testrun and it gave me an error
                       Running checks for 17 modules...
                      ❌ Error: Command failed: npx tsx scripts/check-modules/index.ts
                      npm warn exec The following package was not found and will be installed: tsx@4.21.0
                      [2026-01-23T17:21:24.195Z] [ERROR] [check-modules] Schema validation failed for modules.stage.4:
                      /modules/6/keywords: must NOT have fewer than 1 items
                      /modules/8/keywords: must NOT have fewer than 1 items
                      /modules/15/keywords: must NOT have fewer than 1 items
                      Any idea?
                        After installing tsx (npm install tsx@4.21.0) it gave me a new error:
                        🔎 Running checks for 17 modules...
                        [2026-01-23T17:25:32.134Z] [ERROR] [check-modules] Schema validation failed for modules.stage.4:
                        H KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
