    obsession with modul checker
    19 Posts 4 Posters 7.9k Views 4 Watching
    • H
      HeikoGr
      you need to put the script inside the folder of the module you want to check - not the MagicMirror folder itself
      htilburgsH 1 Reply Last reply
      • htilburgsH
        htilburgs @HeikoGr
        @HeikoGr
        So it is not possible to check all the modules in one run?
        I have to do it for each module?
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        • H
          HeikoGr @htilburgs
          @htilburgs my main objection was to support the module development. so yes, at the moment it’s a per module check,
          • htilburgsH
            htilburgs @HeikoGr
            @HeikoGr
            Oké, clear. Thanks for the quick replys
            KristjanESPERANTOK 1 Reply Last reply
            • KristjanESPERANTOK
              KristjanESPERANTO Module Developer @htilburgs
              @heikogr Nice idea! I’ll take a closer look.
              • H
                HeikoGr
                @htilburgs now it should work for all installed modules
                • htilburgsH
                  htilburgs @HeikoGr
                  @HeikoGr
                  So now I put It in the MagicMirror folder?
                  • H
                    HeikoGr @htilburgs
                    @htilburgs the script looks if it is under an magicmirror/modules folder and takes this as root folder for modules.
                    otherwise it will take /opt/magic_mirror/modules
                    if your setup is different you need to adapt the script.
                    the script itself can be placed independently
                    htilburgsH S 2 Replies Last reply
                    • htilburgsH
                      htilburgs @HeikoGr
                      @HeikoGr
                      Oké, thank you
                        sdetweil @HeikoGr
                        @HeikoGr the script could check and provide a parameter
                        • htilburgsH
                          htilburgs @htilburgs
                          @heikogr
                          I gave it a testrun and it gave me an error
                           Running checks for 17 modules...
                          ❌ Error: Command failed: npx tsx scripts/check-modules/index.ts
                          npm warn exec The following package was not found and will be installed: tsx@4.21.0
                          [2026-01-23T17:21:24.195Z] [ERROR] [check-modules] Schema validation failed for modules.stage.4:
                          /modules/6/keywords: must NOT have fewer than 1 items
                          /modules/8/keywords: must NOT have fewer than 1 items
                          /modules/15/keywords: must NOT have fewer than 1 items
                          Any idea?
                          • htilburgsH
                            After installing tsx (npm install tsx@4.21.0) it gave me a new error:
                            🔎 Running checks for 17 modules...
                            [2026-01-23T17:25:32.134Z] [ERROR] [check-modules] Schema validation failed for modules.stage.4:
                            H KristjanESPERANTOK 2 Replies Last reply
                            • H
                              HeikoGr @htilburgs
                              @htilburgs i guess your modules are missing the minimal requirements for MagicMirror modules in the packages.json file.
                              I managed to lower the requirements…
                                @htilburgs In case you haven’t seen it yet: You can also check https://modules.magicmirror.builders/result.html#MMM-MyHomeWizard-by-HTilburgs. Thats the result of the checks on what you pushed to GitHub.
                                • htilburgsH
                                  htilburgs @KristjanESPERANTO
                                  @KristjanESPERANTO
                                  Thanks, I didn’t know about this.
                                  This is the result of running the script?
                                  • H
                                    HeikoGr @htilburgs
                                    @htilburgs it‘s the original script. My script only tries to run this script locally on demand
                                    • htilburgsH
                                      htilburgs @HeikoGr
                                      @HeikoGr 👍
