    Default weather module - only showing one location
    11 Posts 2 Posters 867 Views 2 Watching
      Ausnet
      Newb.
      Have my MagicMirror2 up and running with a few different modules. I have local weather working with openmeteo. Trying to add a second location (bottom_right) but it stays stuck on “Loading…”.
      I set up an openweathermap.org API key but I don’t get any weather data using the openweathermap provider for local or remote locations
      Should I be able to see multiple locations?
      Current config below. I’ve also tried a copy of the openmeteo modules to get the Brisbane weather but it did not work.
      I searched for similar issues but couldn’t find anything newer than 2022 and the advice on that post didn’t help.
                              module: "weather",
                              header: "Current Weather",
                                      weatherProvider: "openmeteo",
                                      type: "current",
                                      lat: [myLat],
                                      lon: [myLong],
                                      showPrecipitationAmount: true,
                                      showPreciptitationProbability: true,
                                      showUVIndex: true,
                                      degreeLabel: true,
                                      colored: true,
                              module: "weather",
                              header: "Forecast",
                                      type: "forecast",
                                      lat: [myLat],
                                      lon: [myLong],
                                      showUVIndex: true,
                                      fadePoint: 0.33,
                                      maxNumberOfDays: 6,
                                      degreeLabel: true,
                                      colored: true,
                              module: "weather",
                              classes: "brisWeather",
                              position: "bottom_right",
                                      type: "current",
                                      locationID: "2174003",
                                      degreeLabel: true,
                                      colored: true,
                                      units: "metric",
                                      apiKey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                              module: "weather",
                              header: "Forecast",
                                      type: "forecast",
                                      showUVIndex: true,
                                      fadePoint: 0.33,
                                      maxNumberOfDays: 5,
                                      degreeLabel: true,
                                      colored: true,
                                      units: "metric",
                                      apiKey: "xxxxxxxxxxxxxxxxxxxxxxxx",
        sdetweil @Ausnet
        @Ausnet OpenWeathermap new v3 apikey uses
        lat/lon instead of location
          sdetweil @Ausnet
          @Ausnet are you using MMM-Pages? (classes: properties)
          the openmeteo don’t have classes: and wouldn’t be displayed by default on pages
            Ausnet
            Ok - so I tried the following - still said “Loading…”
            Replaced it with the same location as my local area and it came up.
            Restored it to the Australian location and now it’s working :/
            The only thing left is that it’s still displaying in Fahrenheit for Australia even though units are set to metric for those modules.
                                    module: "weather",
                                            type: "current",
                                            lat: -27.24796,
                                            lon: 153.00886,
                                            degreeLabel: true,
                                            colored: true,
                                            units: "metric",
                                    module: "weather",
                                    header: "Forecast",
                                            type: "forecast",
                                            lat: -27.24796,
                                            lon: 153.00886,
                                            showUVIndex: true,
                                            fadePoint: 0.33,
                                            maxNumberOfDays: 7,
                                            degreeLabel: true,
                                            colored: true,
                                            units: "metric",
              sdetweil @Ausnet
              @Ausnet what is units: above the module list set to?
                Ausnet @sdetweil
                @sdetweil before the modules it’s set to imperial. Do the settings in the inner modules not override the outer setting?
                        timeFormat: 12,
                        showperiod: true,
                        units: "imperial",
                  sdetweil @Ausnet
                  @Ausnet I thought so, but this module looks at the global value for some reason
                    sdetweil @Ausnet
                    @Ausnet can you tell me what version of MM you are running
                    grep version ~/MagicMirror/package.json
                      also set tempUnits:“metric”
                      from the doc
                      tempUnits
                      What units to use for temperature.
                      If not specified, the module uses the units value from config.js. <-----
                      Possible values: config.units = Specified by config.js, metric = Celsius, imperial = Fahrenheit
                      Default value: config.units <-----
                        Ausnet @sdetweil
                        @sdetweil said in Default weather module - only showing one location:
                        It’s showing 2.34.0
                          Ausnet @sdetweil
                          @sdetweil That did it. Thanks!
