    Troublesshooting config
    9 Posts 2 Posters 661 Views 2 Watching
    • V Offline
      videogame95
      this is my config file if I remove the page everything show up fine but with pages installed I lose the weather saying loading and the calendar but sometime the calendar
      var config = {
          address: "localhost",
          port: 8080,
          basePath: "/",
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
          useHttps: false,
          language: "en",
          locale: "en-US",
          logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          timeFormat: 24,
          units: "metric",
                  // MMM-pages controller
                  module: "MMM-pages",
                          ["MMM-OpenWeatherMapForecast", "clock"], // Page 1
                          ["calendar", "clock"],                   // Page 2
                          ["MMM-OpenWeatherMapForecast", "calendar", "clock", "compliments", "newsfeed"], // Page 3 (All)
                          ["MMM-OpenWeatherMapForecast", "calendar", "clock", "compliments", "newsfeed"]  // Page 4 (All)
                      fixed: ["MMM-MotionDetector"], // Keeps motion detector running in the background
                      rotationTime: 10000, // Optional: auto-rotates every 10 seconds. Remove if you want manual control.
                  module: 'MMM-page-indicator',
                  position: 'bottom_bar',
                   activeBright: true,
                  module: "clock",
                  position: "top_left"
                  header: "US Holidays",
                              symbol: "calendar-check",
                              url: "https://calendar.google.com"
                  module: "MMM-OpenWeatherMapForecast",
                  header: "Weather",
                      apikey: "192baf050dxxxxxxxxf1a10d32088c93fb",
                      latitude: 51.5775,
                      longitude: -0.1786,
                      iconset: "4c",
                      forecastLayout: "table"
                  module: "compliments",
                  position: "lower_third"
                  module: "MMM-MotionDetector",
                      captureIntervalTime: 1000,
                      scoreThreshold: 200,
                      timeout: 3000
                  module: "newsfeed",
                  position: "bottom_bar",
                      feeds: [
                              title: "BBC England",
                              url: "https://feeds.bbci.co.uk"
      shows up on different boot ups?
      any help please
        sdetweil @videogame95
        @videogame95 which mmm-pages are you using?
          @videogame95 the calendar will show every 40 seconds
          Not for 10 seconds page 1
          Yes for 10 seconds page 2
          Not for 10 seconds page 3
          Not for 10 seconds page 4
          Repeat
          I don’t know that weather module. Does it restart when shown?
          What is the refresh time for weather?
          • V Offline
            videogame95
            The weather and the calendar both just in loading not coming up. I could try a different weather module any suggestions? their are different way of adding the pages look at 3rd party pages see which ways best to use .
            any help please and thanks
              @videogame95 yes there are two different ways of coding the pages
              You can use the module names as you are doing
              I always found this frustrating. Looking at a module config, I had to scroll back to the pages config to find out where it was and then scroll back to the module config, where was that?
              So I documented the page classes approach
              In pages
              Call them useful names , page1,page2, mom, dad, kids, house
              Then at each module after the module:
              Add
              classes:"page1”,
              Or whatever page (or space separated list of page names)
              On the pages config fixed, I use “on_every_page”
              This also solves the problem with multiple of same module on different pages(weather current on one forecast on another)
              But I also am confused, as the latest pages config uses a different timing variable name?
              • V Offline
                videogame95
                Thanks what are page position can i use as see that s missing and could not see
                any on the list use could give me a list of position I can use in pages like top-left
                would this be the correct way to write it in the position space? I’ve seen it on
                other modules but can remember all the position .
                thank for your help
                • V Offline
                  videogame95
                  I have a copy of my config before adding page I’ve replaced it with that one so I can add the pages to that one if its working always make a copy before add any new modules.
                  thank again
                    @videogame95 positions are unchanged in pages
                    See https://docs.magicmirror.builders/modules/configuration.html#position
                    We can only show or hide modules
                    Pages module makes virtual pages by only showing selected modules in defined groups, hiding all the others
                      @videogame95 change the update time in pages to 20 seconds to test
                      20000 ( milliseconds)
