    pages
    15 Posts 2 Posters 1.0k Views 2 Watching
    • V Offline
      videogame95
      Re: [MMM-Pages and MMM-page-indicator](how to select the page?)
      i did put on pages but I don’t have a touch screen would the frame touch screen work in front or behind mirror glass ?
      i add pages but my calendar stopped loading and so did my weather module ? I’ve add my config to a post troubleshoot .
      any help please
      S V 3 Replies Last reply Reply Quote 0
        sdetweil @videogame95
        @videogame95 I posted in the other topic
        Without touch, you would need a functional mouse device.
        Some remotes can do that.
        The ir frame would have to go on top of the glass, aka in front
        • V Offline
          videogame95
          thank you
          • V Offline
            videogame95
            ok thanks’ for you help do you know how to install pages with have 4 pages rotation. any help please.
            S V 2 Replies Last reply Reply Quote 0
              @videogame95 I don’t understand
              at the top of MMM-pages config there is the modules list
              its an array [] (list of logical pages) of arrays [] (list of modules names on page)
              or alternately using the class approach
              its an array [] (list of logical pages) of arrays (with single entry of page name)
                      module: "MMM-pages",
                          timings: {
                              default: 20000,      // rotate every 20 seconds
                              2: 30000,            // page 2 rotates every 30 seconds
                              "admin": 30000       // admin hidden page auto-returns after 30 seconds
                              ["page0"],           // class name for page 0
                              ["page1"],           // class name for page 1
                              ["page2"],           // class name for page 2
                          fixed: ["on_all_pages"],
                          hiddenPages: {
                              "screenSaver": ["screensaver_page"],
                              "admin": ["admin_page"],
              then in the class approach, you add
              classes:"page0 page1",  // space separated list of page names
              after the module:“weather”, // for example
              (on every module you want displayed)
              the module provides page rotation, using the
              timings: {
                              default: 5000,               // rotate every 5 seconds  // all pages rotate every 5 seconds
                              0: 20000,                    // page 0 rotates every 20 seconds // except page 0 hold for 20
              every module provides a README.md file, (what is shown on github landing page for module), that is the module DOCUMENTATION
                @videogame95 said in pages:
                when using pages, ALL modules you want displayed MUST be added to the pages config thru its module name, OR the classes: property added,
                else the module will NOT be displayed…
                • V Offline
                  videogame95 @videogame95
                  Hi thanks I’ve added the first config it worked in I add the page, my
                  open weather maps did’t show up so update script and it worked but when moved Backgroundslideshows it stopped but i was wrong after a little while it came on the page I had set it to. Please explain how to up the second cofig.
                  ? or all go in the brackets.
                  i haven’t looked at it for while .
                  hope you understand
                  please explain best you can simplest way
                  I’m having difficulty in setting google what I’ve done
                  1 made project name photos1
                  2 googlephotos api added and enabled
                  3 downloaded credentials rename to
                  4 added it in modules folder in google photos folder
                  5 saved id code numbers in Geaney
                  6 published it
                  7 tride run code in terminal. code node v.2 run token something like this
                  8 did found
                  not sure what I’ve missed out ?
                    @videogame95 pages
                    In the
                    Module config ( I am only doing the page definitions here
                        modules:[
                                        [     List of comma separated dom content by  css class names, (in quotes) module-name is also defined  as a class name], // first page
                                        [     List of comma separated dom content by  css class names, By( in quotes) module-name is also defined  as a class name], // second page
                                         [. Repeat as needed ],  // <- notice the comma after each set of brackets
                    The easiest way for me is to make up nice names for the pages
                    “Mom”, “Dad”, “stocks”, “son”, etc as many as you need/want
                    Each of those is a page above,
                    Now in each actual module config, on a line after the
                    module:"calendar",
                    Or whatever module
                    Add a line
                           classes:"xxxxxx",
                    For example,
                    classes:"Mom Dad”,  // notice the comma here too
                    Where xxxxxx is one of your page names you set like above
                    If a module should show on more than one, but not all pages , add those page names too, space separated
                    Mmm-pages has a shortcut for modules that should show on ALL pages. The fixed: property . It’s also a space separated list
                    I just set it to “all_pages”, and use that in the classes: for those on all pages.
                    EVERY module needs a classes property set.
                    Google Photos is broken after Google changed the way you select and group photos
                    Someone has a sort organic new version, announced here in the last couple weeks.
                    Did I get all your questions?
                    • V Offline
                      videogame95
                      thank you that was well explained
                      I look forward to the new google photos will this be in 3rd party modules or on googles cloud console ?
                      or github ?
                        @videogame95 here is a link to the topic here with link to GitHub
                        https://forum.magicmirror.builders/post/130057
                        • V Offline
                          videogame95
                          I’m going to trying to add my config of my UK national Rail not loading
                          i got the token from national Rail Data Portal
                          module: ‘MMM-page-indicator’,
                          position: ‘bottom_bar’,
                          activeBright: true,
                          module: “MMM-UKNationalRail”,
                          position: “top_right”,
                          header: “Departures”,
                          station: “RDH”,
                          token: “d921e466-a91e-4b3f-96a0-ba476081”,// <— REPLACE THIS WITH YOUR TOKEN
                          module: “newsfeed”,
                          position: “top_center”,
                          feeds: [
                          title: “BBC World News”,
                          url: “https://feeds.bbci.co.uk”
                            @videogame95 are you using mmm-pages? Did you add the module to some page?
                            No classes: specified
                            Do it has to be added to some page list, right?
                            • V Offline
                              i installed uk national rail module but its not losading
                              any help I got the token from here LDBWS / OpenLDBWS)
                              i got ant email. after login in.
                              it comes up with only loading but never dose.
                              yes run install script again.
                              Any help please
                              • V Offline
                                videogame95
                                I’ve added uk natioal rail to page 2 which is page 3 . just comes up loading
                                  @videogame95 loading means the module is waiting for data to display, but it has not arrived.
                                  Can you look in the output where MagicMirror is started
                                  Npm start or using pm2
                                  If using pm2, then the command
                                  pm2 logs —lines=xxx
                                  Where xxx is the number of most recent lines of output, default 15. So you may need xxx to be 100 or more
