    Universal-PIR - ‘GPIOcommand exited with error'
    3 Posts 2 Posters 966 Views 2 Watching
    • K
      Klinge
      After completely reinstalling my MMM, the MMM-Universal PIR module no longer works for
      I get the error message
      My configuration is as follows
          module: "MMM-Universal-Pir",
          gpioCommand: "gpiomon -r -b gpiochip0 17",
          onCommand: "wlr-randr --output HDMI-A-1 --on --transform 90",
          offCommand: "wlr-randr --output HDMI-A-1 --off",
          deactivateDelay: 180 * 1000,
      The cables are connected with the sixth pin and the first and third pins on the other line.
      I tried the solution in the here on the bottom but unfortunately I cannot found a compose.yaml.
      It would be great, if you can help me.
      Thank you in advance.
      Klinge
      • karsten13K
        karsten13 @Klinge
        @Klinge
        from the module README.md:
        Please test the used commands first outside of MagicMirror². If they not work from a terminal it makes no sense to use them inside this module.
        So what is the output if you run gpiomon -r -b gpiochip0 17 on your machine?
        And provide the version with gpiomon -v
        K 1 Reply Last reply Reply Quote 1
        • K
          Klinge @karsten13
          @karsten13 Thank you for your advice.
          To my shame, I must admit that I did not read the readme.md file.
          Yes, after reinstalling I am using Trixie and I have to use the gpiomon V2
          So with
          gpiomon -e rising -c 0 17"
          it works
          Thank you again
          • K Klinge has marked this topic as solved on
