    Speaker sound after copying SD card
    Scheduled Pinned Locked Moved Forum
    2 Posts 2 Posters 1.5k Views 2 Watching
    • M
      MilkShake
      Can someone help troubleshoot my sound settings on my RPI4 with Raspbian OS? I use the MMM-Sounds module to trigger sounds at different events, but since copying the SD card to a new one, it seems to have lost the ability to play wav files. Cannot remember how I used to set it up!
      When i do Aplay sound.wav nothing happens it plays the wav with no sound.
      When I do aplay -l:
      card 2: Device [USB2.0 Device], device 0: USB Audio [USB Audio]
        Subdevices: 1/1
        Subdevice #0: subdevice #0
      When I do:
      speaker-test -c2 -twav -l7 -D plughw:2,0
      the speaker outputs front left…front right…front left…etc. so I know it is working.
      Thanks a lot for the help!
        sdetweil @MilkShake
        @MilkShake try
        aplay -D plughw:2,0 xxx.wav
        If you make an ~/.asoundrc
        You should be able to set the default output device
        Notice the . In front
