    MMM-ImagesPhotos
    10 Posts 2 Posters 2.2k Views 2 Watching
      Ray
      So I decided to try MMM-ImagesPhotos And when I installed it in my magic manor everything went very well, but
      now my MMM-TouchButton Doesn’t want to function
      I have no clue here why this is happening and to verify it I removed
      MMM-ImagesPhotos And the MMM-TouchButton Worked once again
      Am I missing something here I tried to slow down the reloading of the images and that didn’t seem to work
      Here are the two configurations that I’m currently using
      			disabled: false,
      			module: "MMM-ImagesPhotos",
      			position: "middle_center",
      			 opacity: 0.9,
      			 animationSpeed: 7000,
      			 updateInterval: 7000,
      			 maxHeight: "500px",
      			 maxWidth:"500px",
      			 sequential: false  // process the image list randomly
      		   // all .SH files Must be simple no dashes of any kind just names
      		   // and they must be in the MMM-TouchButton script folder
      		   // to execute a script file like stop.sh
      		   // put ./ in front of stop.sh
      		   disabled:  false,
      		   module: "MMM-TouchButton",
      		   header: "Controls  MagicMirror",
      			buttons: [
      			  icon: "fa fa fa-power-off",
      			  command: "pm2 stop MagicMirror",
      			  args: ""
      			  icon: "fa fa-window-minimize",
      			  command: "wmctrl -k on",                 // this actually minimizes all active windows
      			  args: ""
      			  icon: "fa fa-snowflake-o",
      			  notification: "MODULE_TOGGLE",
      			  payload: {hide: [], show: [], toggle:[]}
      The settings in MMM-ImagesPhotos Are the default settings
      any help would be appreciated
        Ray @sdetweil
        @sdetweil thanks to all of your help I found the solution
        It took a while to figure it out but all I had to do was add
        position: relative;
        on top of z-index: 5;
        and it works perfectly
        .MMM-TouchButton {
        	position: relative;
        	z-index: 5;
        Thanks for all of your help this room is awesome
        R S 2 Replies Last reply Reply Quote 0
          sdetweil @Ray
          @Ray what is your touchbutton config
            Ray @sdetweil
            @sdetweil I’m not sure I understand the question The configuration I included in my question up above hereWhat more would you like
              sdetweil @Ray
              @Ray sorry, didn’t hit the config to scroll
              Buttons top left
              Images middle center
              One thing you could do is set the background of the top-left to see where it is, middle-center is left edge to right edge.
              I think it is on top of top left, closer to you as the user
              You might have to force z-index on buttons to get it in front/on top of middle-center
              .MMM-TouchButton {
                  z-index:5;
              Positive number closer to user,
              negative number is further away.
              0 is the normal baseline
              That also means the buttons will show on top of the images
              R 2 Replies Last reply Reply Quote 0
                Ray @sdetweil
                @sdetweil Sorry I haven’t replied until now
                thanks for the info I will certainly give this a try and feels that helps
                I actually have the program opened up right now I’m going to add it and see what happens
                  Ray @sdetweil
                  @sdetweil Well I just tried it and unfortunately did not work
                  when the picture shows up the MMM-TouchButton doesn’t want to function
                    sdetweil @Ray
                    @Ray ok try this in custom.css
                    img #mmm-images-photos {
                       z-index:-1
                      Ray @sdetweil
                      position: relative;
                      .MMM-TouchButton {
                      	position: relative;
                      	z-index: 5;
                        Ray @Ray
                        I will continue to test it but I don’t see any problems
                          sdetweil @Ray
                          @Ray awesome!!!
